Chipper Chipper Blade Sharpening
/ Chipper Blade Sharpening #41
For what its worth, a service rep at the US distributor for Valby/Farmi told me that a one degree difference in the prescribed angle of a chipper knife will have a significant effect on chipper performance.
OK, so for those of us with used chippers and are just following what the last guy may or may not have screwed up, what is the correct angle?
/ Chipper Blade Sharpening #42
Whatever the owner's manual tells you it should be.
My Patu is 30.5 degrees.
/ Chipper Blade Sharpening #43
"MY" BearCat #554 calls out a 45* angle...
If "U" own a bearcat you can call Crary and ask for instruction sheet for
replacement chipper blades.
Shreader bades are different...
/ Chipper Blade Sharpening #44
I sent my Salsco knives to Salsco for sharpening...they offer sharpening service. When the blades start to get dull, I can also reduce the distance between the knife edge and anvil (there's an adjustment for this) and this helps, although feed speed is reduced somewhat.
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2017 Ford Fusion Hybrid Sedan (A61569)
2017 Ford Fusion...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61567)
2024 Kubota...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2013 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2DJ296618 (A61165)
2013 International...
