Chinese Chipper Feed Drum Modifications
/ Chinese Chipper Feed Drum Modifications #1
gav64
Bronze Member
Eastern Connecticut
Mahindra 2810hst - Gehl 4625 skidsteer
Has anyone modified the feed system on the jinma chipper to better feed small, green stuff. The chipper works great on drier larger limbs but does not feed the smaller stuff well. I was thinking to either add more aggressive paddles to the drum or decrease the space between the drum and the bottom of the feed chute. Also has anyone out there widened the feed chute to accomodate wider branches. thanks glenn
/ Chinese Chipper Feed Drum Modifications #2
I had considered sharpening the teeth on the feed drum. The concern is this, if the drum doesn't slip on the branch then the belt has to slip. The belt that turns the drum does not have a clutch.
Closing the gap may help and make smaller chips in the process. Let us know but I'm not sure that this chipper will ever chop up the twiggy stuff very well. A shredder would be good on the small twiggy stuff.
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2014 Caterpillar 420F (A64126)
2014 Caterpillar...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
2020 Ford Explorer SUV (A61574)
2020 Ford Explorer...
