Chimney Liner Question's
/ Chimney Liner Question's #1
WhyNot
JD 2210
Chimney Liner Question\'s
I like to do things myself but, I thought I would let a pro place a stainless liner in my chimney for a new pellet stove that is until I took a half day from work to wait for him to see what he needs to do the job didn't want a quote or nothing just the job done and he didn't show. So I'm going to do it myself but have a couple questions <ul type="square"> [*]1. Will the attached diagram work as far as the bends in the liner? [*]2. Installation guide calls for 3" for up to 15' EVL (equivalent vent length) mine is 19' EVL so it recommends 4" vent but, 4" won't fit between the existing heat tubes. Anyone see using 3" a problem or if the 4"can be ovaled to fit? [*]3. What is the blanking plate used for that needs to be fabricated to seal the firebox off from the flue with a hole only large enough for the vent to pass through? [/list]
I tried to let a local "pro" do this but........
Thanks in advance /forums/images/graemlins/smile.gif
/ Chimney Liner Question's #2
Re: Chimney Liner Question\'s
What software is needed to open your document? What product is this that you plan to use?
I don't like one bit, when someone says when they will show, and then do not show, nor call - ever! No apologies, no excuses, just nothing. Happens so much now it's pitiful, to say the very least. I wanted to dump the guy that said he would do my shower room for me, and even acted like he really wanted to do it. That is, until we got into the 'meeting' a schedule or even making a schedule that he would like to follow. Hopefully, after 7 weeks, next week it will happen. /forums/images/graemlins/wink.gif
/ Chimney Liner Question's #3
The Blanking plate blocks drafts from the chimney.I think it should be made of metal.
Check with the stove man. for the size of vent pipe for the difference you have. Again I think the 3 inch may work.
Egon
BeenThere,
I'm new to this posting thing what I did was drew a sketch in MS paint and the file was to large to attach so I made it into a zip file and of course it worked for me because it's saved to my hard drive so if you or anybody else has any suggestion's throw em at me
/ Chimney Liner Question's #5
I'am in the hvac plumbing business,and I can tell you that I always go by the manufacture installation instructions.Engineers designed & tested this to work as it states in the installation instructions.In my business if you stray from these instructions & something happens ,LOOK OUT ! I'am liable ! /forums/images/graemlins/blush.gif
/ Chimney Liner Question's #6
</font><font color="blue" class="small">( I'am in the hvac plumbing business,and I can tell you that I always go by the manufacture installation instructions.Engineers designed & tested this to work as it states in the installation instructions.In my business if you stray from these instructions & something happens ,LOOK OUT ! I'am liable ! /forums/images/graemlins/blush.gif )</font>
I see 2 problems.
#1) You mean we have to read the instructions? I would need to find them!
#2) Then the last step is some Eng designed it? Great, there goes the planet! /forums/images/graemlins/grin.gif
/ Chimney Liner Question's #7
(No prob with your zip file by the way)
I'm with kenmac, I've installed 2 wood stoves, complete, and around here at least, the mfg instructions are the "code". So when the inspector came out, there was no UBC or anyother source governing the installation but the mfg. FYI, I'm not all that big on permits and have my share of bootlegs but, when it comes to wood burning appliances, if I don't have a permit for it, and it causes a house fire, my insurance won't cover it. Not sure how things are in your area. Good luck with it.
/ Chimney Liner Question's #8
I converted your bitmap to a GIF and reposted it - less than 1% of the original size.
Next time you can just pick ".gif" from the "Save As Type" box when saving the picture in MS Paint.
thanx for the advice and doing that for me
/ Chimney Liner Question's #10
Mike, you know that we would be lost without guys like you
/forums/images/graemlins/confused.gif
/forums/images/graemlins/smirk.gif
/ Chimney Liner Question's #11
You know me. I see both sides here. But I had to add that! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2022 EZ-GO ELITE...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
