Chimney Fire - Is it Possible with a Selaed Insert?
   / Chimney Fire - Is it Possible with a Selaed Insert? #41
It's much more humid on this side of Washington state then the east side that i was familiar with when burning wood. The softwoods like fir or pine dry pretty well after a year in the wood shed, but that oak was so much denser then our usually firewood. I burn some cherry, alder and maples, which are denser and take a little longer to dry then the fir and pine. Love the oak though.
Correct. While our winter humidity regularly runs over 80%, it is possible to get dry wood after 1, often 2 years. My wood runs around 14 to 17% when I burn it.
   / Chimney Fire - Is it Possible with a Selaed Insert? #42
For some maybe; A harness and rope setup will accomodate most any roof, and is a one time buy with countless future uses; a manlift may not be able to access the area, as in my case where the gable end is adjacent to a 2 bay garage, limiting access to the chimney altogether. And $160/day may be reasonable once but not 2x/year, every year, IMO.
One would think that. I have a round 6" pipe with cap. An option is for stainless screen to insert it. I had some same size galvanized screen so I tried that because of cost. Didn't work. Plugged up very fast. Burned Dry wood and hot fires. I am thinking as the smoke cools it accumulates. I took the screen out and will try to find a larger screen.
On 10/12 metal roof at peak so everything needs to be planned out well before I make a move. I installed a bracket on the roof to hook an extension ladder half to reach the thing comfortably and safely. Ext ladder to get on first level roof then another ladder to scale the long steep metal section. I just need to find a bigger screen than what the pipe company suggests and offers.[/Q
Chimney Liners | WoodlandDirect.com: Chimney Liner Parts, Rigid Chimney Liner, Aluminum Chimney Liner Kits-Woodlanddirect.com is just one store that offers every possible solution to chimney lining. Note that any chimney liner should have an insulation wrap installed around its entire length to keep the SS liner consistently warm from top to bottom, and to protect the surface of the original chimney materials from becoming too hot. Also offered is a powdered mix that hardens after being poured between the exterior of a SS liner and the original flue material. This mix is easily used when there is low clearance between liner and flue. Caps with and without screens and high wind type caps are also offered.
BTW, I have a long length of screw together 6" dia. SS liner, in addition to a flexible section of SS, and some Metalbestos sections, both from when I retrofitted my chimney and went to gas insert fireplaces. They are for sale, also a Jotul woodstove and a (not sure of brand) wood fireplace insert that were removed from my main house and my flip property, when the renovations to gas heat were implemented. If interested send me a PM to find out more.
Thanks,
CM
Here is the POC super cap I got that lets little birds through. When I bought it originally thought it is not bird proof, and I was correct. Also the manufacturers sized screen I tried to no avail. Possibly I need a bigger screen because all is well except for the few birds that can sneak through in the spring when FP is off more often. Maybe I'll perch an owl on top, a heat resistant one.
I would go for an eagle - I just like it better and I really do not think it wold matter to the little birds, any big bird will do.
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
1261 (A50490)
1261 (A50490)
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
