greg_g said:
Maybe you should first consider what size tractor is going to USE this half ton boxblade. Rather than join the throng that's wandering down this side street, how about tailoring your response to the original question posed by WORKINALLTHETIME? I don't believe you can find argument to the fact that there's a certain limit to the weight of a boxblade that an 1852 pound tractor can effectively handle. He only wanted to know if - given the circumstances he described - that United boxblade would be ok
//greg//
Nowhere in this thread, nor in any other thread on this forum will you find a post of mine directed at you (excepting this one). Yet, you have posted a strongly worded reply directed at me that impunes me, my experience, opinion and advice. Were you posting correct, it would not be an issue, however it is not correct.
Read Post #14 - I recommend that the original poster buy a 5.5' 700# box blade. Did you not see that? His 4x4 30 hp tractor has an FEL that weighs about 1000-1200# with the bucket - he lives in OK where it is not exactly mountainous. He will be able to drag a 700# box around. His 3pt lift is 1650# at 24" behind the arms, more that enough for 700#. My assumption is that the ground in OK is hard, often dry, possibly with a layer of caliche, possibly clay. Not easy to work. A light box will not work very well in the conditions prevalent in the area the original poster lives in. All of that data was used to form my opinion as seen in post #14.
Read Post #38 - Highbeam added 400# to a light box - he notes that it performs dramatically better. He also notes that he is now a firm believer in additional weight on a blade for more effective cutting in hard materials.
Read post #42 - I don't direct the original poster to buy a half ton box. I do ask Highbeam to add more detail to explain that heavy is better than light for ground engaging equipment. I have seen that many people make claims that they do quite well with light box blades. My assumption is that like Highbeam, they don't have experience with an equivalent width heavier box.
The original poster, Workallthetime, actually does mostly commercial work with his equipment. My experience guides me to stand by the advice that he will be better served with a box in the 5.5' and 700# range. I also still stand by him investigating a rollover box for his commercial work.
Have a Great Day!
jb
