rickmacheske
I have the united box blade. It works fine for me. It's not all that light and so far I haven't broke it.
Adding weight in your case may cure the symptoms, but does not address the cause. You can usually fix the issue of "sliding over the ground" by changing the angle of attack. If you can't pull the toplink up short enough to put a more aggressive angle on the blade with the scarifiers down, simply buy a shorter toplink.flusher said:But the XB is way too lightweight to scrape turf off the ground (something I do a lot of around my place). With the scarifiers in the full down position, I end up with four ruts and the blade just slides over the turf. Add the weight and the XB cuts turf nicely.
patrick_g said:I bought a Cammond box blade. Cammond is a good brand. It had hydrraulic scarifier raise and lower. In a few weeks I had bent the tube supporting the scarifiers and They fixed it under warranty. Then I bent it agin worse. They gave me all but $50 of the original price to upgrade to an industrial strength box blade they make. It is a 6 footer that weighs about 1000 pounds. I haven't found a way to bend it. I don't have to add weight to get it to cut but I do nhave TNT and the top cylinder will push back on it and make the blade dig in. Alternatively I can lower the 3PH arms and pull up on the top to dig the scarifiers in with little contact of the rest of it with the dirt.
They make smaller ones also. This thing looks like it will last forever unless I hook it to a monster tractor, something many times the HP of my 40 HP Kubota.
Home Page
They have a NEW grading scraper somewhere between a box blade and a grader.
Pat
jacobweaver32 said:The problem I am having now is that I can't level out the waves in the graded area.... all holes and bumps are gone but the broken up dirt is now wavy as ****.
