Check your top links!
/ Check your top links! #1
moojamboo
Bronze Member
Nothern Vermont
Ford 1710
So I am doing some logging with my Norse winch. I start a pull on my log and after about 4 feet BAAM. I look back (was watching the log pull) and my top link came apart and my winch was laying flat on the ground, still spinning on a now extremely flexed pto shaft. I killed the engine quick as I could. My fault, I had the link set for my plow, and instead if adjusting the right way I just kept spinning more and more thread out. I guess she had been holding on by a thread (pun intended) for a while.
It was comical. Huge winch, flat on the ground. Took a while but got her back up, all hooked up and nothing broke, but could have been deadly if standing in wrong spot. Would have killed one of my dogs in an instant if I let them around while I worked.
So, check you top links, and equipment in general!
/ Check your top links! #2
I guess, a stop at the end of the threads has been tried. It probably presented other kinds of problems.
/ Check your top links! #3
This happened to me, but the winch didn't fall all the way flat because its bottom jammed against a rear tire. The PTO was still attached, so I ran the cable over the ROPS to a tree in front of the tractor and "winched the winch" back to where I could reattach the top link.
Now there is a mark on the top link threads that means "go no farther." A safety chain is another solution.
I ended up having to use my hydraulic floor jack and blocks of wood to angle it up high enough so I could push it back up. I thought of tying a chain around the top of it and laying across rops and then hooking to loader and lowering lower to pull it up, but thankfully I didn't need to mess with that!
/ Check your top links! #6
I had a malfunction with my boxblade once due to just the opposite. I had shortened the top link as much as it would go so the scarifiers would dig in more. I was moving along digging up some deep rocks with the scarifiers and suddenly the boxblade flipped over with the top link hanging down by the drawbar and it was riding on my back tires. I didn't think that you could shorten a top link too much but this one did and I was lucky the boxblade didn't damage a tire or climb up into the cab with me.
/ Check your top links! #7
I sure wouldn't have seen that coming. Who knew? But, it does make sense.
/ Check your top links! #8
Gary, you mean the top attachment point on the BB went "over center" of the top link knuckle? That must be unusual!
Jim
/ Check your top links! #9
The top link is not meant to withstand winch forces. If the link holds you will finally break the attachment point to the tractor. The pull point should be lower so that the lift links take a large %.
larry
/ Check your top links! #10
I have have same thing happen to me as Gary stated twice actually. Buy doing the same thing having the link drawn in all the way on a BB. The box blade inverts and contacts the tires and possibly the back of our finders. If this does happen the first thing you think to do is lower the BB. Well when it in inverted the controls are now inverted. When you lower it you actually are pushing it further toward your finders and tires. Not Fun!
/ Check your top links! #11
I use a Farmi 501 winch which has both an upper and lower snatch block. The upper block is recommended for pulling until the load is a few feet from the winch.So far this has not caused any problems for the top link or the attach point on the JD5105m.Recently I replaced the mechanical top link with a 3000psi hydraulic link but have not used it on the winch yet. Any opinions on whether this should cause a problem? Thanks.
/ Check your top links! #12
What Spyderlk said, GOTTA use that lower pulley for MOST of the skidding in, the upper is for lifting onto the carrying chains.
Top links are little more than turn buckles, not rated for n thousand pounds of pull.
I have to believe that using JUST The top pulley could break a top link (even if you have many turns of thread engaged) ANYWAY if a log hangs up and you are on just that top pulley. It is ABOVE the top link, so there is a lever at work multiplying the cable pull - lower links are actually in compression :D
Using that top pulley for skidding raises the line far too high, two problems with that a) If/when something lets go the cable is going to whip around HIGH off the ground - think decapitation. b) It has the potential to pull the tractor over backwards, while your attention is on the logs coming in - depends on tractor size, winch capacity, drag, etc.
BTW, I think the rule of thumb is that THREE turns of a screw hold things together, after that more don't help i.e. when 3 strip the 4th goes then there is a cascade failure- the whole durned thing strips out.
/ Check your top links! #13
I'll "theorize" on it;
From memory the 501 boasts somewhere around 11,000 lbs line force.
If you use the bottom pulley MOST of the pull against the tractor should be shared between the lower link arms and the ground(dig in, let the tractor get pulled back until your "anchor is SET").
My guess is that the hydraulic top link SHOULD come under relatively little tension -IF you do things right (I don't always do things right).
/ Check your top links! #14
... ... BTW, I think the rule of thumb is that THREE turns of a screw hold things together, after that more don't help i.e. when 3 strip the 4th goes then there is a cascade failure- the whole durned thing strips out.
:thumbsup: This rule of thumb is out there, but dangerous to follow w/o some critical thot. 1st note that every standard nut you find provides an engagement length approximately equal to the minor diameter of the bolt. This turns out to be about 5 threads on coarse pitches and nearer 10 on fine. Both of course include a safety factor; however it is important to note that more fine threads have to be engaged to get proper thread area. The best thumb rendition would be that length of engagement should be at least 70% of the bolt minor diameter. BUT, altho this would provide full axial clamp, or straight tension capability, it would not be fully durable to extreme off axis loading where the pull vector could shift/oscillate a bit. Hence the observed nut/bolt engagement convention of ~ 90% minor diameter. More for bolts into castings which tend to be unpredictably weaker than a Graded bolt.
larry
/ Check your top links! #15
Reg&Larry-thanks for your advice on the top link situation with the Farmi. I checked the 501 manual and on pages 18 & 19 they suggest using the top pulley for winching the load.When I have done this vs. the lower pulley there is far more shaking of the tractor and obviously more loading on the top link-which is why I raised the question.In the future I will be using the lower pulley since this will minimize the chances of a broken top link as well as a flipped tractor. Andy.
/ Check your top links! #16
Please don't take this personally, but I do KNOW about the Farmi manual and I have disagreed and written to them about it many times over the years.
Yes, I get that it produces a slight down force that helps dig the dozer blade in.
Yes, I get that it provides a SLIGHT up angle to the pull that helps butts off the ground.
It is STILL not worth pulling against your tractor any higher up than absolutely necessary.
They seem to ignore a natural tendency to watch the log and ignore any back tipping of the tractor.
A couple of feet higher pull point on 100 or 150 ft cable doesn't lift a butt over anything very much :D
but could make a big difference to stresses on the tractor and its stability.
2013 MAGNUM PRODUCTS LIGHT TOWER (A60736)
2013 MAGNUM...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A60352)
2002 Chevrolet...
Kivel trailer mover attachment (A61567)
Kivel trailer...
2018 ADDCO ROAD SIGN DH1000-ALS (A60736)
2018 ADDCO ROAD...
2020 DRAGON ESP...
TRANSPORT SYSTEMS 35LX AD DOUBLE DROP (A60736)
TRANSPORT SYSTEMS...
