Check your suction screen filter
/ Check your suction screen filter #1
ChrisNJ
NorthWest NJ
JD 4310 e-hydro
4310 Hydro. Was just doing my 50hr service. When I pulled out the suction screen (long, metal one in the lower trans case housing) I found the screen was broken. At first I was concerned but after looking into it, it only looks like a pre-filter to the main spin-on suction filter. However, just a note to look at it if anyone does a trans fluid change. The new one was spot welded, not continous, so it can't be very efficient, but it did have a lot of junk on it.
/ Check your suction screen filter #2
I did my own as well. Didn't have too much junk in it. There was still plenty of area open for the fluid to pass by. The screen seamed to be in tact. This is just a pre filter to get the big chunks usually from the assembly process.
/ Check your suction screen filter #3
I changed my transmission fluid at 25 hours since my 3 PT hitch would not lift. Didn't see any problems with the suction side filter and both spin on filters did not look bad either. It did the trick and the 4510 is working normally now.
Sure would be nice if there was a way to check the prefilter without having to dump all the fluid. Could be just a couple of valves to isolate the filters.
Red
Re: Not really big deal
After doing the whole 50 hr service myself, my assessment would be that the you probably could wait till 100hrs. non of the filters had much on them except for the pre-suction screen, but it too still had a lot of surfacr area left as it is pretty large. I would still do the engine oil but my trans fluid and filters could have easily have waited. One thing cool, was while changing the hydraulci filter, a saw a tag (on the trans???) that sais 'SAUR something" Made in USA!!! pleasantly suprised!!
/ Check your suction screen filter #5
I have a 4300 hydro and learned by accident that there was a recall because the suction screens were coming loose and getting the insides fouled up/ My dealer picked up and redelivered theb tractor and apparently welded the suction screen into place so It would not come loose.
/ Check your suction screen filter #6
We just got a 4310 in December, and are nearing the 50 hr service. Do you know if the recall was just for the (older) 4300, or does it include the (newer) 4310s, as well. Also, the manual says to replace the side suction filter at the 50 hr service, but the dealer (Barnett in Snohomish, WA) said he talked with someone in service at Deere, and they said don't bother. Comments?
/ Check your suction screen filter #7
In a brand new tractor I like to change all the filters and oils. I like to think that any filings or metal shavings that might have made it through the birthday process will be caught by the first filters. Probably just peace of mind.
/ Check your suction screen filter #8
nothing shows on the "10" series
Here's the one on the "hundred" series
Solution Number: 53475
Doc ID: LV53475
Solution Summary: PIP 01LV058 – Tractor Transmission Suction Screen Improvement – 4200, 4300, 4400 Series Tractors
Publication Date: Nov 20 2002
DATE: 25 January 2002
JOHN DEERE COMMERCIAL AND CONSUMER EQUIPMENT DIVISION
JOHN DEERE COMMERCIAL PRODUCTS - AUGUSTA
PROGRAM NUMBER: 01LV058
TITLE: 4000 Series Tractor Transmission Suction Screen Improvement
CLASSIFICATION: Mandatory Mechanical
PRODUCTS AFFECTED:
LV4200C426269-426480
LV4200H421408-422650
LV4300C435387-435531
LV4300H431834-433016
LV4300S437027-437518
LV4400H441369-442201
LV4400S446341-446611
Some machines in this P.I.N. range were repaired at the factory. An exception list of those tractors will not be printed. JDIS software users, use your on line "PIP Register" or reference your "PIP STATUS" screens for tractors involved in this program.
SITUATION:
The transmission sump screen can fall into the bottom of the transmission due to inadequate bonding of the screen to collar. Unfiltered oil can enter the hydraulic system. The transmission gears may ingest the screen.
SOLUTION:
A new sump screen assembly is introduced which incorporates a recess in the collar for a more secure bond of the screen.
Goosen Bale Chopper Hay Blower (A65579)
Goosen Bale...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
Fire Ring (A65640)
Fire Ring (A65640)
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
Landhonor Quick Attach Power Rake (A66285)
Landhonor Quick...
