Check Chains Alternative
/ Check Chains Alternative #1
wvpolekat
Platinum Member
Buckhannon, WV
1947 Ford 2N and 2003 Kubota B7500
So, I mangled the check chains/rods assemblies on my B7500. Looked up the parts at Messick's and it will run me about $160 for them. Bit much for some 1/2" all thread and some nuts welded to pieces of strap.
So, i am looking for alternatives.
Right now, I am thinking about some 1/4" chain with turnbuckles or some other method of tightening them. Figure I can put that together for about $20-30.
Any other ideas?
/ Check Chains Alternative #2
I don't know about the B7500, but on my B7800 I installed the "telescopic stabilizers" from the B2910 when by turnbuckles gave up the ghost. That was the best $150 I have ever spent on the tractor. Soooo much better than turnbuckles. I don't know if the same conversion is available for the B7500, but Messick's should know if you give them a call.
/ Check Chains Alternative #3
You can get Generic check-chains like you described, but you need to get graded turn-buckles and speaking from experience, it's best to just get them from a tractor supply place. Messicks probably has them. I know Hoye tractor (another sponsor here) does.
However, for the price, I'd be tempted to go with the telescopic stabilizers that Dr. Bob is talking about. I almost wish my "threaded rod" would break so I have an excuse to upgrade :)
Thanks for the tip on the telescoping ones. I found them on the diagrams, total is going to be $195.06. Looks like it should be a bolt on conversion. I think the $30 will be money well spent as it appears to be a more robust setup. I may be able to save a few bucks on some of it by not using Kubota parts, but I doubt it is worth it.
For now, I picked up some chain and associated bits and will cobble something up to work in the mean time. Picked up a couple of light duty turn buckles that I am sure I will destroy quickly. But it will keep it out of the tires for the time being.
Quantity Vendor Part Number Description Cost
2 Kubota 02174-50160 NUT $1.50
2 Kubota 04512-60160 WASHER $0.35
2 Kubota 04015-60160 WASHER, THICK $0.70
2 Kubota 6C070-65350 BOLT,STABILIZER $5.93
2 Kubota 05122-51235 JOINT PIN $2.39
4 Kubota 04011-50120 WASHER $0.18
4 Kubota 05511-50425 PIN $0.18
2 Kubota 6C070-65333 ASSY STABILIZER $20.30
2 Kubota 6C070-65340 PIN,STABILIZER $5.93
2 Kubota 05515-61000 PIN $1.06
2 Kubota 6C070-65320 PIPE,STABILIZER $20.30
2 Kubota 6C070-65310 BRACKET,STABILIZ $36.46
2 Kubota 05122-61245 JOINT $1.89
/ Check Chains Alternative #5
I believe Tractorsmart also has a telescoping arm kit available for reasonable money.Good Luck!
/ Check Chains Alternative #6
I bought a tap and a die in 1/2" - 13 L from ENCO and make my own turnbuckles.
The preferred way - don't buy solution, buy tools:thumbsup:
Tractorsmart does have a "kit" Stabilizer for a little bit less.
I would love to build my own and I imagine I could even do telescoping ones without too much trouble, but I don't have the time/tools to do it.
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
78in Heavy Duty Hydraulic Grapple Rake Skid Steer Attachment (A64553)
78in Heavy Duty...
