Check Chains Alternative
/ Check Chains Alternative #1
wvpolekat
Platinum Member
Buckhannon, WV
1947 Ford 2N and 2003 Kubota B7500
So, I mangled the check chains/rods assemblies on my B7500. Looked up the parts at Messick's and it will run me about $160 for them. Bit much for some 1/2" all thread and some nuts welded to pieces of strap.
So, i am looking for alternatives.
Right now, I am thinking about some 1/4" chain with turnbuckles or some other method of tightening them. Figure I can put that together for about $20-30.
Any other ideas?
/ Check Chains Alternative #2
I don't know about the B7500, but on my B7800 I installed the "telescopic stabilizers" from the B2910 when by turnbuckles gave up the ghost. That was the best $150 I have ever spent on the tractor. Soooo much better than turnbuckles. I don't know if the same conversion is available for the B7500, but Messick's should know if you give them a call.
/ Check Chains Alternative #3
You can get Generic check-chains like you described, but you need to get graded turn-buckles and speaking from experience, it's best to just get them from a tractor supply place. Messicks probably has them. I know Hoye tractor (another sponsor here) does.
However, for the price, I'd be tempted to go with the telescopic stabilizers that Dr. Bob is talking about. I almost wish my "threaded rod" would break so I have an excuse to upgrade :)
Thanks for the tip on the telescoping ones. I found them on the diagrams, total is going to be $195.06. Looks like it should be a bolt on conversion. I think the $30 will be money well spent as it appears to be a more robust setup. I may be able to save a few bucks on some of it by not using Kubota parts, but I doubt it is worth it.
For now, I picked up some chain and associated bits and will cobble something up to work in the mean time. Picked up a couple of light duty turn buckles that I am sure I will destroy quickly. But it will keep it out of the tires for the time being.
Quantity Vendor Part Number Description Cost
2 Kubota 02174-50160 NUT $1.50
2 Kubota 04512-60160 WASHER $0.35
2 Kubota 04015-60160 WASHER, THICK $0.70
2 Kubota 6C070-65350 BOLT,STABILIZER $5.93
2 Kubota 05122-51235 JOINT PIN $2.39
4 Kubota 04011-50120 WASHER $0.18
4 Kubota 05511-50425 PIN $0.18
2 Kubota 6C070-65333 ASSY STABILIZER $20.30
2 Kubota 6C070-65340 PIN,STABILIZER $5.93
2 Kubota 05515-61000 PIN $1.06
2 Kubota 6C070-65320 PIPE,STABILIZER $20.30
2 Kubota 6C070-65310 BRACKET,STABILIZ $36.46
2 Kubota 05122-61245 JOINT $1.89
/ Check Chains Alternative #5
I believe Tractorsmart also has a telescoping arm kit available for reasonable money.Good Luck!
/ Check Chains Alternative #6
I bought a tap and a die in 1/2" - 13 L from ENCO and make my own turnbuckles.
The preferred way - don't buy solution, buy tools:thumbsup:
Tractorsmart does have a "kit" Stabilizer for a little bit less.
I would love to build my own and I imagine I could even do telescoping ones without too much trouble, but I don't have the time/tools to do it.
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
PALLET OF CULTIVATOR PARTS & FERTILIZER APPS. (A64278)
PALLET OF...
2022 EZ-GO ELITE...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
