cheap vs expensive: weak vs strong attch's
/ cheap vs expensive: weak vs strong attch's #1
Cidertom
Benton Co Oregon
JD 4520, 2305 Aktive snow-trac ST4
After reading a lot of posts here, I thought I would throw in my observations.
Posts about a particular brand being crud, or good or great, need some reference about use. Most attachments give a HP range, but that is only part of the story. If you use attachments wayout on the edge, don't expect to have them stand up the same as if they are used as pictured on the flyer.
As an example: I had a higher end blade by Rankin, in normal use it had no issues, as soon as I was offset, tilted, and angled and hung up on a pipe it tore the blade off the mount.
If you are going to use an attachment gently, infrequently, and as designed, then the lower cost items will perform well. You may never notice the unsupported welds on certain yellow attachments, and the higher cost of the buff colored ones would be a waste. Look at the weight and cost. Looking the other day the cost of blades seems to follow the squared law: as the weight doubles, the price quadruples. On the other hand, if you are ripping up mud-stone then the cheaper ones won't last and that money will be wasted.
Look at your needs, look at your neighbors equipment and compare.
CT
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
2013 International Pro Star (A64911)
2013 International...
2027 Terext Light Plant (A67714)
2027 Terext Light...
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
2012 MERTZ FRAC MANIFOLD TRAILER (A67714)
2012 MERTZ FRAC...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
