Cheap, Lightweight Cab
/ Cheap, Lightweight Cab #1
Shadow99
Southwick,MA
Pasquali 993 w/FEL, Economy2414 w/FEL
I got one of those snowblower cabs for $10 at a tag sale several years ago, it never got mounted on to my 1964 Gilson Snowblower. But I did find a creative use for it on 2 of my compact tractor's. First the frame's overall height was shortened using S.S. hose clamps I had on-hand, (so I could clear garage door). Then it was backwards mounted, onto the seat spring on my 1971 Enconomy 2414, when I was using it to plow snow. Kept my upper body protected from the elements & wind. Now that the Economy is retired (for now), I mounted the same shorten frame onto my Pasquali 993.
It provides about the same amount of protection, lower extremites (upper thigh & legs) were exposed before too. But it's better than nothing!:thumbsup:
Shadow
/ Cheap, Lightweight Cab #2
You don't see one like that every day, very cool!
Refering to the tractor or the cab? I do get some strange-looks from folks that drive by, they have never seen a small-tractor like that before.
Yup, I sure am. Got 6' blade mounted on 3pt, Cozy-cab on, now just need SNOW!!!
Shadow
/ Cheap, Lightweight Cab #6
Pretty cool setup, but I'd be gasping for air. (claustrophobic lol) Love the Terra tires!
If you are facing into the wind, and it's blowing hard. The cab fills up like a parachute, the loose fitting bottom skirts blow-out like a pressure relief valve, which can cause issues with the lift-arms. Ripped some new clearance slots, in the skirt the other day when picking-up grader blade to max height. Fabric got caught on something, and wha-la new ventalation holes!
Shadow
Ok, learned some stuff with having my "cozy-cab" on while trying plow 10" of heavy-wet snow, in the rain & darkness of this morning. Can't see squat, need a wiper option! Other than not being able to see while backing-up (even with a back-up light), it kept my torso dry. Would have rather had 18" of puffy-snow, than the wet-stuff, but that's life in New England; wait 10min & the weather will change.
Shadow
/ Cheap, Lightweight Cab #9
go to the junk yard and get a wiper set up off a rear gate of a mini van or suv the cheapest option i know of i hope this helps
That is a good idea & cheap option! Hadn't thought of that. Was thinking of having my canvas buddy sew-in a reinforced window opening, that rolls up & is held with snaps or velcro. Simular to a "dodger" on a boat, simple & costs a 12 pack!
Shadow
/ Cheap, Lightweight Cab #11
Shadow
You guys work cheap up there...........we work for 30 packs here in Pa.:laughing:
He likes the good stuff, he's worth it.
Shadow
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
2013 Ford F-450 Reading Service Truck (A61573)
2013 Ford F-450...
