Charles Machine Works M4 Trencher
   / Charles Machine Works M4 Trencher #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Hi All,
A good friend of mine borrowed a trencher from another friend and just dropped it off leaving me to figure out what all the levers and wheels do. It a Charles Machine Works walk behind model M4. I did a little internet searching and discovered this is an early Ditch Witch but wasn't able to find any info on how to run the thing.
I think the teeth need sharpening because I was playing and the ground speed seems to be too fast for the trench cutter even at the slowest speed I could figure out.
The ground around here isn't rocky or clay and digs pretty easy. If you lock both wheels it bogs down and tries to pull the cutter up out of the trench. If you leave one wheel unlocked the other wheel spins enough so you can dig but no way it's going to dig a straight trench.
Any trencher experts out there that could give me a few tips? I have about 950 feet of trenching to do and will be able to keep the trencher for probably a couple of weeks.
Bob
Wow over 100 views and nobody has any hints for operating a trencher. I did stop by the local Ditch Witch dealer and believe it or not they still carry parts for this thing. However they said the guy I really needed to talk to was on vacation.. Just my luck /forums/images/graemlins/smile.gif
   / Charles Machine Works M4 Trencher #3
If you take a picture of all of the levers ill be more than happy to try to help you.
Thanks for the response.. Here is a picture of the beast.
Here is a shot from the business end. After looking it over I have figured out that the two levers are connected to a 3 speed transmission that could have came from a early Ford or Chevy. The input and output shafts have been modified for the trencher. If I could remember how the shift levers worked from my 49 Ford days I would have the trans figured out.
The big horizontal wheel lowers and raises the digger, easy one.. Not sure what the lever on the right side of the engine does yet unless it engages the chain drive from the engine. The right wheel can be disconnected from the drive train by loosening the star wheel.
Not sure what the lever on the inside of the right wheel is?
Here is a shot of a couple of the teeth,
Looks to me like they could use a little grinding but I have no idea if I should try to sharpen them or not???
   / Charles Machine Works M4 Trencher #7
Hello Bob,
I just ran across this posting. Are you still looking for this info? I have one of these.
Andy
   / Charles Machine Works M4 Trencher #8
I have no experience with this particular type trencher but it appears to me that one of the cutter teeth is on the wrong side of the chain in the provided picture. It could be that this trencher was made to cut the center between the inside and outside teeth, but with my limited experience I have never seen a trencher built in that manner. The teeth actual look pretty good to me as far as sharp. Sharp edge won't last very long in dirt or rocky ground. My guess is that ground speed is your issue.
   / Charles Machine Works M4 Trencher #9
The teeth appear correct to me. I recently bought a brand new chain for mine (Ouch $$$), and there is a pattern that uses only one left-handed type of tooth, and one right-handed type in combination with varied mounting arrangement to produce a distribution of cutting positions along the width of the trench. The teeth seem OK as far as sharpness, but this machine does NOT have gobs of power to spare, particularly with deeper/wider trenching or harder ground. It looks like it may be set up for about 5" trench width, so it's certainly worth a try before spending a lot of time on the teeth right away - especially if you just have a small job ahead.
As far as travel speed during digging, the first thing I would check is the reducer shift lever (on the reducer assembly next to the right tire in the second photo). It is a flat tab on the reducer that slides up and down several inches in the slot in the reducer. This is a strange thing so be careful. In one position (down, I believe), the entire reducer (with the shift lever itself) will spin rapidly as the machine moves, and in the other, it will lock into the approximate rotation shown in the pic. It looks like the the lever may be in the lower position, which is the MOBILE position. This would only give you ONE speed in the digging direction (which is actually reverse mobile) and three in the opposite - and these will be much too fast for digging operations. You need to make sure that the lever is in the upper (DIG) position. Again, in this position, the housing (and lever) should lock into position and not rotate when digging. In DIG mode, you will get three travel speeds in the digging direction (1st gear is quite slow here - you have to watch closely to see the wheels spin) and one reverse to back the trencher up during trenching. Only change these settings with the slip (Master) clutch disengaged and ALWAYS watch your fingers/limbs!
Finally, during digging the locking nut (wheel clutch) on the right wheel should be tight during digging (this locks both wheels to the axle so it will run straight), and can be loosened (right wheel free-spins) during "mobiling" to ease turning.
Regards,
Andy
   / Charles Machine Works M4 Trencher #10
Your answering a post from 2004! I hope the OP has the work done by now. But if he works like me maybe not!
   / Charles Machine Works M4 Trencher #12
I dont get it.....The OP (original poster) stated he had use of this trencher for two weeks and asked questions about it. Then someone, 6 years later ,brings the thread back to the top to answer the guy!!!! Why????
   / Charles Machine Works M4 Trencher #13
Guys,
I realized the date of the original posting, but was not a member of this site back then so I didn't see it at the time. My experience with forums like this is that you don't always get what you need, when you'd like it. And with equipment like the M4, there are not a lot of people out there that still operate them - mine was made in 1966. So when I was recently looking for some info on mine, I came across this thread which had a question and no answer. This indicated to me that likely nobody was familiar with this unit - at least back then. I would think that the network would appreciate the sharing of ideas and help on all equipment, whether common or not. So I registered and made a fairly generic reply as an offer to ANY M4 owner that may have been looking for help - even those who may end up here via Google, as I did. I don't think there is any harm in making it known that there is a member that has some knowledge on this piece of equipment. Generally, if I am not interested in a thread, I ignore it and it eventually goes away. One of the few things in life that actually does that. :)
Sorry if I used bad judgment.
Regards,
mowmow
   / Charles Machine Works M4 Trencher #14
Naw...not bad judgment! Your motives were altruistic and you are right in your reasoning for posting. :)
BTW, welcome to TBN. :welcome:
   / Charles Machine Works M4 Trencher #15
And it was very helpfull for me
I bought a m4 ditch witch , seazed wisconsin aen motor, full of water , stuck clutch in gearbox , broken belts ..
i final got it striped and working , would dig fine but was not working in mobile position ..
so now i know where the latest problem is .. so i can strip that part and hopefully i will have a working 1960`s era digger ..
   / Charles Machine Works M4 Trencher #16
That's great to hear. Hopefully, you just need to get the goo out of that planetary gear assembly and you'll be good to go.
Another piece of advice: Get some grease into that digging depth adjustment as soon as possible. Zerk location varies by model year, but they all use a very unique recycling ball-bearing (maybe QTY 50 of ~1/8" balls in a 2" x 2" x 2" block) arrangement that rides around the screw.
I'm still here and just ran 1100 feet of 40" deep trench with my M4 last fall, so ask away if you have further questions.
   / Charles Machine Works M4 Trencher #17
Re: Charles Machine Works M4 Trencherr - Need a new 2x2x2 block
So, here am I, years later, asking about a part for my old M4 Ditch Witch Trencher. The recirculating balls (5/32 ") have escaped before and in the process have damaged the grooves in the soft steel 2x2x2 block so that the batch of new steel balls no longer circulate freely in the block. Any ideas anyone?
   / Charles Machine Works M4 Trencher #18
Does this help?
Every Part. Every Machine. Ever.
   / Charles Machine Works M4 Trencher #19
Thought 1: I assume that you have the screw well-greased after re-assembly, as the arrangement can bind when dry - even if things are otherwise ok.
Thought 2: Maybe you can find a slightly oversized (metric?) ball to make up for the wear, yet still fit through the passages.
Thought 3: I was amazed at the parts that Ditch Witch was still able to sell me for my unit as well as their reasonable price for items the clearly were only used on my model. You should at least check with them.
Thought 4: Have a block custom-made.
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
Year: 2019 Make: Jeep Model: Grand Cherokee Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Pla... (A59231)
Year: 2019 Make...
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
