Charging battery with alternator
/ Charging battery with alternator #61
Whenever I jump someone off, I always do that. I hookup my cables and let it run 10 minutes, then actually shut my truck off before they jump. don't want my alternator to see that .001 ohm load of that starter on their vehicle.. :)
soundguy
/ Charging battery with alternator #62
I looked this up. This link Alternator Output vs. Engine RPM
Shows that at 575 rpm engine speed the output of a 63 amp alternator is only 16 amps. Yes they are better than generators, but they do drop. At idle and a few loads on you may be discharging your battery.
Hi, an alternator is a three phase unit a dc generator is a single phase unit. So, one shaft turn on an alternator cuts thru three magnetic fields and can produce three times as much current as a single phase dc unit.
The reason 80/100 amp alternators are common today is beacuse we need a lot amps at idle so that we can run almost all electrical loads from the alt and not the battery when sitting at a light.
This trend started when we switched over to electric fans for cooling radiator and A/C became almost standard on most vehicles.
cheers,
/ Charging battery with alternator #63
how many cars you got that idle at 575 rpm?
all my vehicles are around 800.
specs i see show up to 60% of rated amps at normal idle speeds.. least a 10/12SI gm does..
soundguy
Just tested my Tundra V8 idle using my OBDII COMPUTER. It was just below 700. Sorry to be so picky. My points are.
1. Alternators are pretty tough and they take care of themselves pretty well. I have had many go to over 150,000 miles and still counting.
2. Do not expect full current at normal idle.
3. It is a lot cheaper to charge a battery with a charger than a large gasoline engine. It saves wear and fuel cost. If you got a charger use if, if not use the alternator.
/ Charging battery with alternator #64
When you are boosting a low battery, I also leave it connected for a while before starting. I use my multimeter to check the voltage before I connect it. When you are boosting a vehicle, your boost battery supplies very little amperage, what it supplies is voltage.
If you have a very dead battery that is why it will not start, the cables can not get enough amperage threw the cables to get the voltage up to at least 9.6 volts while cranking to allow it to start.
I enjoyed the talk about GM. I have a Duramax and everything is always fully covered. Those new Fords with the 6.7's have a fuel filter that allows water threw it, it destroys the fuel system, it is only between $8,500 and $10,000 in parts. It is not covered by warranty period. Go on a ford enthusiast site and look it up.
And if you want a vehicle with a great place to access a battery, that would be a Chrysler Intrepid you have to remove the tire. and the alternator you have to lift the motor, some you need to remove the radiator. 2.5 hours if you have done it before, and 5 if you have not.
/ Charging battery with alternator #65
Thanks, I was searching for a good link and saw that one you supplied. I am rather skeptical of what searches turn up, just wondering if anybody here on TBN had real life experiences with the situation. The part that most interests me about the issue is just how much charge a jump start puts back into a low battery.
I cant' tell you how much charge a jump start puts into a battery..but it can be right considerable. Many times I have seen that when the cables are first connected, the lights will dim in the donor car, but the receiving car won't start.
Within around 5 minutes, it will start.
Based on the spark I see when I connect, I am guessing around 65 amps. It could be higher, and I could be badly fooled. If we knew the resistance of all the components, we could calculate it.
I forget the numbers, but by the time a battery drops to (say) 12 volts, it is mostly discharged. That difference between 12 and 12.6 volts represents most of its charge.
I have never ruined an alternator charging a flat battery...because I make sure it has descent charge before the start.
Batteries left loaded to depletion are not bad batteries. They are depleted (and harmed some by that.) They will aggressively absorb charge.
But many flat batteries are bad batteries..if you hook them to a charger, you will see that they charge up much quicker than the lack of charge would have indicated was possible. Those batteries have lost their capacity and cannot hold much charge. Therefore, they may not represent much challenge to an alternator.
When I use jumper cables, I typically let the cars sit connected for around 5 minutes minimum before I attempt to start. This practice may have saved me some alternator problems. Frequently, I will let them stay connected for around 3 minutes so both systems can charge the weakened battery, and to make sure that the receiving car is warm enough not to risk stalling, forcing me to repeat the process.
/ Charging battery with alternator #66
My multimeter has a min - max function and will display the voltage the receiver battery goes to. The one I am interested in is the minimum. If while cranking you do not have 9.6 volts a lot of vehicles will not start. I always leave my vehicle running.
When I am boosting a vehicle, I normally leave the cables connected for about 5 minutes it allows the boosted vehicles battery to get the added charge from the donor vehicle. It also allows the boosted vehicles alternator to get threw the highest out-put cycle at a lower rate. They really do get hot.
I have very good cables, some day I will connect the clamp meter and see how much amperage goes threw the cables on a start.
/ Charging battery with alternator #67
soundguy
Hi, the amount of watts a starter draws depends on the size,comp.ratio and friction of the engine that needs turning over. Most fully charge batteries dip to 10.2 to 10.4 volts while cranking over. Battery cold cranking amp rating plays a big role here. What any starter needs is watts so the higher the static supply voltage while cranking the lower the amps will be. Amps generate heat and cause voltage drops so it's best to get the watts needed from voltage.
Soundguy's idea of turning off his vehicle when lending a boost is a smart one.
Voltage regulator from boost vehicle seeing a 10.2/10.4 voltage signal will go to full charge for as long as it sees it. This is not conducive to long electrical component life.
While it is true that the dead cars electrical system will suck up most of these boost amps it is still a good idea not to tempt fate.
cheers,
I remember in the older days the advice for jump starting usually told us to turn off the radios and all electrical items in the car being boosted, the idea was that by not having lights, etc. on, the battery being boosted would have more current to send to the starter, and by having the radio off, it wouldn't be "damaged by a current surge"....:laughing:
Has anyone ever known about a radio that was left on and was damaged? I never heard of that happening.
/ Charging battery with alternator #69
I noticed that when I turn on the AC the engine rev go up about 100 RPM. So this would give more alternator output.
/ Charging battery with alternator #70
agreed on all points.
oem alts seem to last the longest.. replacements and rebuilds from there seem to be a roll of the dice.
I don't expect max rated output at idle.. I expect enough output at idle that it will handle all of the vehicles rated functions without having a discharge situation at idle.. thus why you see a car with 90a or higher alternators.. that way they can idle and still put out 45+ or higher amps..
a bat charger is better if ya got it.
if stranded in a desolate area and you got a jump pack and it will get you going.. you do what ya gotta do..
soundguy
/ Charging battery with alternator #71
why leave it on to consume and waste power that needs to be going to a starter.
that's akin to turning on the ac, radio and all the lamps on both vehicles before starting.
it is a waste. let the amps for the starter and the battery.
soundguy
/ Charging battery with alternator #72
idle up solenoid pretty common setup...
/ Charging battery with alternator #73
No idle up solenoid anymore. They used to have them. Now there is a steeper motor that controls idle speed. The idle air motor.
/ Charging battery with alternator #74
same function...
/ Charging battery with alternator #75
Hi, "Charging battery with alternator" sure that is what they do. A wind turbine spins an alternator to make power and batteries are used to store the power.
been doing allot of research about alternator's charging batteries. still much more to learn though.
- alternator's are rated at 100 percent duty cycle
- alternator's produce 115v AC current, the diodes make it 115v DC
- alternator regulators keep the DC current at about 14.6v (perfect to charge)
- alternator's optimal shaft speed is 5,000 rpm, maximum usable is 7,000 rpm
- alternator's are designed to charge batteries and supply power for other loads
- Do Not disconnect the battery with engine running (diodes will burn out)
in this picture to the left is my work in progress 6.5hp dual alternator charging system.
currently it only has one Delco 12-si 94 amp alternator (internal regulator). i have recently received the second short alternator mounting bracket. both stainless steel. the neat thing about the internal regulator is that the field exciter is switched so battery/load can be removed with the engine running. down side is if not switched off it will drain the battery, with a One Wire alternator the engine can be left to just run out of gas
the Epicenter has instructions on how to, before listing items which can be DIY, they are also BBB accredited. Notice in the first link the Dual alternator setup 12v and a 24v.
More Home made generator projects!
Building your own generator.
Building a high power AC/DC generator system!
Convert a lawn mower into a generator!
Yup, alternator's can also be modified to weld. Engine RPM controls the output doing so, and a rheostat can be added to control the field input current to fine tune for even TIG welding. Lots more for me to learn or just spring for the $800 plus for a pre-made unit (ZENA). ZENA also has some awesome high output alternators (100 percent duty cycle).
EDIT: also 1 hp is recommended for every 25 amps of alternator output at 100 percent load.
/ Charging battery with alternator #76
I am surprised an automotive alternator puts out 115 VAC and gets regulated down to near battery charging level. I would have figured it closer to say 17 VAC at full field strength. I will try to review the links this weekend and heal my ignorance (or put some salve on it so it quits itching for a while.)
/ Charging battery with alternator #77
Pretty hard to find an outlet for a charger many times, so to say I am 100% correct is not always right. And how many of us carry a charger around? So far I have not seen anything about how much a charge jump starting puts back into a low battery, although one member said it's a good idea to connect the two batteries together for a period of time and let the good battery charge the run down one.
Problem is, in the very rare cases I have asked a stranger to help me jump start my vehicle (once in the last 25 years) I pretty much hate to ask them to stick around an extra 5 or 10 minutes.
I have my trusty 4AMP charger in my garage at all times in case the battery dies at home, and if it doesn't, I carry my Battery Booster in the trunk to jump start it, but luckily, the only flat batteries I've had so far have been at home, so I've been able to use my charger rather than the booster.
/ Charging battery with alternator #78
i carry a jump pack in my f450 'toy hauler' not so much for the diesel.. but for any 'toys' that may need a jump to trailer them. the jump box has a plug in 1a charger to charge the jump pack. If you leave the jump pack paralleled to the batter and plugged in.. it works as a 1a harger. slow.. but works.. otherwise jump pack has a tire inflator, led work lamp and a 12v power outlet.. kinda handy..
soundguy
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
Ripper Tooth Excavator Attachment (A61572)
Ripper Tooth...
429858 (A61165)
429858 (A61165)
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
New Holland 3930 (A60462)
New Holland 3930...
