bmaverick
Super Member
- Joined
- Sep 17, 2013
- Messages
- 6,931
- Location
- Beloit-WI
- Tractor
- Yanmar YM2610 ■YANMAR GURU■ EXTRAORDINAIRE
I find it odd that no one mentioned the removal of caps (if not sealed top) prior to charging. This allows the hydrogen to freely vent from the top area that is free of acid/water mix so as not to accumulate and possibly cause an explosion when a spark occurs.
Connecting the clamps prior to plugging in the charger is a good idea but doesn't guarantee no spark if a bad connection is made but at least you wont be nearby if it does explode. Same with disconnecting, kill the power to the charger first.
The Yuausa and the Schumacher are microprocessor controlled. If you try and smack the two battery clamps together, no sparks. Likewise when placing them onto the battery. There must be something that flips a relay or something to then make a charge once the microprocessor senses things.
