Charging A New Battery?
/ Charging A New Battery? #21
Well i go thru a bunch of batteries probaly 5 in last couple of years. I use a battery hydrometer on mine if it was a std core battery. Resting voltage would be the only indicator of your battery mystery eather letting it stand 24hrs or loading with electrical load 10-20a for 5-10minutes.
A good alternative is the spiral core batteries offered at sams club or walmart might have one.
My solution to it was a dry cell battery http://www.odysseyfactory.com/ or genisis battery. Supposidly they last 7-10yrs and are used in aircraft starter batteries of certian sizes. That's what i'm going to try there approx. $133 and alot lighter weight. probaly 10-12# vs 50.
They also have special tractor batteries and good range of replacement batteries.
/ Charging A New Battery? #22
Mike, I don't think you can beat an Optima battery, especially at those prices. It's always possible to get a bad one of any brand occasionally. Optima and Delco are the only totally sealed batteries, (no acid fumes ruining your tractor), that I am familiar with, and their Optima prices are down in the range of Delco.
/ Charging A New Battery? #23
I would be pissed if I brought home a bad "optima"
I brought one home but it didnt fit in my JD 4100..
The optimas have the weired cylindrical shape to it, and it was bigger than the spec's stated....Not sure where i could get a small 435 CCA delco sealed battery, any suggestions?
Duc
/ Charging A New Battery? #24
"Not sure where i could get a small 435 CCA delco sealed battery, any suggestions?"
K-Mart carries them in my area, (Fl), you might try them, if you have one. I have a 14 year old car, first Delco lasted 10 years, have 4 years on the second, absolutely no acid fumes.
/ Charging A New Battery? #25
So your saying that the fumes from the batteries can wreck the radiator as well as the battery acid? So everybody who had a leaky battery with NH and JD may have radiator problems they don't know about? I don't know much about batteries. /forums/images/graemlins/frown.gif
/ Charging A New Battery? #26
Yes, a battery in front of a radiator will corrode the radiator eventually, if not sooner. It is a very poor engineering design.
/ Charging A New Battery? #27
I don't see where else they could put the battery. There are no steps to put it in like larger ag tractors and the engine compartment is full with the engine on the smaller compacts.
/ Charging A New Battery? #28
I have a modern cut that has ~20yrs the battery is in front of the radiator. No sign of corrosion.
and i think the dry cell batteries are superior to any spiral core batterys due to design. small and light weight with no liquid fluid to worry with.
/ Charging A New Battery? #29
There are lots of places other than in front of a radiator to put a battery... I've got two tractors with batteries under seats, and 2 with the battery, in a mid engine mount behind the dash.
Also, keep in mind, many paints are sulfuric acid resistant... A properly maintained radiator may be completely safe from the fumes, if the paint is intact.. etc... If it is waering thin.. don't see why you couldn't hit it with some more paint... every time a radiator leaves our local radiator shops, they paint them.. even if it is just a solder job... top to bottom paint.. etc.
Soundguy
/ Charging A New Battery? #30
I can see moving the battery closer to the dash and moving the engine slightly forward but under the seat in a moden compact would be hard with the rockshaft and transmission components there. Are your tractors newer or really old? Just curious. I think if it was really a problem the companies would not have designed it that way. Or they did it just to cut cost somewhere.
/ Charging A New Battery? #31
Many older tractors had it under the seat or over a rear axle next to the fender. Some had them under or beside the rear of the hood area. Putting them in front of the radiator is good for assembly and manufacturing, but a bad idea.
/ Charging A New Battery? #32
You are fortunate to have no corrosion. Not so with many CUT owners. Perhaps you radiator is coated with something. Some CUT's have a "sealed" lead acid battery with a vent tube that routes the fumes down below the radiator. This is a good idea, however the replacement batteries seem to be only available at a dealer for an outrageous price. Of course this boosts dealer profits with expensive battery and radiator sales, so for the manufacturers it is a win/win situation.
/ Charging A New Battery? #33
Those dealer only batteries are known as "GOTCHA".... same size battery at Wally World for an Audi is $39.99 ..... at the dealer, it is $239.99 plus installation. The difference is that the Wally World battery has a hold down tangs on the long side and the Audi original has it on the short end sides..... That is the total difference. Without that, the battery can not be clamped in place. I learned this when I took my neighbor to get a new battery when hers failed this summer.
/ Charging A New Battery? #34
They run the range of really old to newer. After posting, I also went to check out on our heavy equipment. And again.. found every type of mounting scheme thinkable... side of engine, mid engine.. ( some mid engine mouns had the battery higher than the engine, even with fuel tank.. so engine wasn't pushed forward..e tc... lets see.. under foot rests, ahead of foot rest, lower side of engine, front lower side of engine, directly in front of radiator..go figure... in front of radiator, but lower to not block it.. , under seat, behind seat
stradled on either side of tranny, under , before or after foot rests... ok thats it.. That is from everything from a lawn tractor to 50's and 60's era tractors, to larger industrial tractors from the 70-90's, and some small non-name brand inports from the 90's ( eicher, mahindra, etc ).
As for problems with the tranny... just depends on the setup... on my NH .. the tranny, is below and forward of the operator.. but then.. I have a cushing glide seat .. so no room there.
One thing I noticed.. with the various combinations of mid-mount batteries.. they obviously has the shortest run to the starter/alternator connections... less BIG copper to route around on the tractor... I really like that.
Soundguy
/ Charging A New Battery? #35
</font><font color="blue" class="small">( Without that, the battery can not be clamped in place )</font>
I've seen that.. easy to get around... for a couple bucks you can get the universal tie down that has a bar across the top, and an eye on each side. A long screw with a hook goes thru each side to hook to something... almost always you can find something to hook to. The some rubber washer go on, and a couple of wingnuts.. then the oem battery people can
'kiss-off' .
Soundguy
/ Charging A New Battery? #36
not a thing to hold to on this vehicle....... I also know about universal mountings..... on newer cars everything is a shoe horn fit to say the least!!!!
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
