char lynn motor question
/ char lynn motor question #1
pairofhounds
columbus ga
2015 Cat 305
have a char lynn 2000 series motor 104-1063 with 1 1/4" keyed shaft. Its missing the key.... is it a standard key stock or do i need to go through Eaton/char lynn? never dealt with this and need a little help... thanks!
/ char lynn motor question #2
I'm not a machinest but pretty sure that "keystock" is pretty std in size. I think it comes in about 12" legnths, just cut it to legnth. An industrial supply or maybe even a good auto parts store can get you a pc. Grainger & prolly fastenal will surely have it. Measure real carefully or bring your motor along for a good snug fit.
low carbon steel or zinc? which is harder? high torque high speed mower application
/ char lynn motor question #4
http://www.hydraulicstore.com/index.php?loc=items_detail&data[history]=&data[catalog]=1&data[itemcode]=5959084
If you look closely at the shaft, you'll see that the key doesn't go clear to either end of the shaft - that's because that particular motor (and several others) use what's called a Woodruff key, sometimes known as a "half moon" key -
The shaft is NOT grooved full length for a Woodruff key, instead a circular milling cutter is lowered onto the shaft in one place, making a half-moon shaped POCKET into which the key is placed before sliding the pulley or gear onto the shaft over the key, which sticks up from its pocket.
The gear or pulley IS grooved full length of the bore, and usually a set screw is run through the pulley/gear directly in line with the keyway, so when the set screw is tightened it locks shaft, key and gear/pulley all together and bottoms out the key in its pocket.
I couldn't find specs on that particular motor, but usually there are several standard size keys depending on shaft size, etc -
Rusty steered you right on possible sources, but it'd help to have a manual for the mower - might give you more info on which key material, etc... Steve
How about leaving the key out and drilling a 3/8 hole in the motor shaft and installing a shear bolt for protection? ??is that stupid?
/ char lynn motor question #7
How about leaving the key out and drilling a 3/8 hole in the motor shaft and installing a shear bolt for protection? ??is that stupid?[/
Don't go that route.Those keys cost pennies.
Any machine shop, many auto parts will stuck them.
Probably can get an assorted kit on EBay
I need to incorporate a shear bolt in my driveline and that might be a decent place to do it...
need a shear bolt between motor and gearbox.. anything wrong with drilling hole in charlynn motor shaft?
/ char lynn motor question #10
I 2nd what PILOON says: don't drill it. The shaft is prob hard steel, too, so it will be hard to drill.
That said, many applications that use hyd motors will use a relief valve as a safety, instead of
a shear bolt. The latter is used more for PTO apps. What is yours?
If I am out of key stock, I have used new 1/4" steel lathe cutting tools, which work great.
how about using the existing hole in the 6 spline coupler and getting a piece of .500 wall tube steel to slide over it?
GATOR UTV (A63276)
GATOR UTV (A63276)
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
3146 (A63117)
3146 (A63117)
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
International S1900 (A63689)
International...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
