Channel iron strength
   / Channel iron strength #31
Low Bucket
They are not Mobile home axles they are Camper trailer axles 3500 lb With brakes on all 4 wheels the bolt pattern is what they call "Dexter Star" and Wheels are hard to find for them. I have a 1985 23' Yellowstone Camper that has same Pattern but 14" wheels. The frame is a Camper frame 2X4" with 3" channel welded to bottom for additonal strengh. Plan on hauling about max of 2 tons on it.
   / Channel iron strength #32
I haven't decided if I am going to put a tailgate on it or not. Do you have any thing over the wood floor on the inside. I wasn't sure how well dirt would slide on wood. I was thinking of using wood and putting a piece of liner like we use in the dump trailers at work over the wood. I wouldn't have to lift as high with the liner.
Bill
The wood floor has worked out good. I think one time I was hauling wet red clay and it builded up in the front corners some. Other then that no trouble and I have dropped some big rocks ( not by choose ) in it.
If you don't make it to remove the tail gate, just keep it in the back of your head. You said you weren't going to put a tail gate on it, I think after you get it done you well put one on.
A liner sure would help and you are right about maybe not having to go as high. I think you were thinking a 5 X 8 trailer, if so without a tail gate you well not hvae alot of dirt in it. The tail gate well give you one more bucket full. After a few load the trailer sure seems like it gets smaller, and smaller. At the end of the day you well be thinking it's only a wheelbarrel full.
Well have fun building it and I'm sure it well be done right and do what you want it to do.
   / Channel iron strength #33
Bill
You will end up putting a tailgate on it, at least plan for it now so it is easier. You will want one as soon as you use it.....
I was thinking some used tin siding would make a floor over the wood floor - take a little abuse, slide a little better, keep the wood dry.
--->Paul
   / Channel iron strength #34
(quote) I was thinking some used tin siding would make a floor over the wood floor - take a little abuse, slide a little better, keep the wood dry.
Paul I think I well try that, just because It's a good, cheap ideal. Good one!! But I haven't had any trouble with that, never know just might.
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
2003 Big Tex 10PI...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
