Changing leg hydraulic filter on mahindra 4110. Tractor
   / Changing leg hydraulic filter on mahindra 4110. Tractor #1
Hillborne
Princeton, ma.
Mahindra 4110
unless you pull off the rear tire there is no way to get the metal case out-- unless you can take the two bolts that hold the plate in which the metal case is attached. Has anyone tried removing the holding plate?
Thanks
   / Changing leg hydraulic filter on mahindra 4110. Tractor #2
If you're referring to the large metal canister suction filter under the right side, yes, you remove the whole canister out from under the tractor and then separate the end from the can and replace the cartridge filter inside. I unbolt it from the side of the trans, bracket & all. Be careful with the 90 degree rubber elbow hose at the rear of the canister that connects to the trans case - that hose is a different size on each end and not easily acquired. This filter is the suction side filter going from the trans case to the 2 hydraulic pumps, be careful not to allow any debris to get to the pumps when servicing this filter assy.
Skip Marcy,
Thanks so much for your reply to my question. You answered exactly what I needed to know.
Thanks again.
Hillborne
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
Vermeer V800 (A50324)
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
