Changing leg hydraulic filter on mahindra 4110. Tractor
   / Changing leg hydraulic filter on mahindra 4110. Tractor #1
Hillborne
Princeton, ma.
Mahindra 4110
unless you pull off the rear tire there is no way to get the metal case out-- unless you can take the two bolts that hold the plate in which the metal case is attached. Has anyone tried removing the holding plate?
Thanks
   / Changing leg hydraulic filter on mahindra 4110. Tractor #2
If you're referring to the large metal canister suction filter under the right side, yes, you remove the whole canister out from under the tractor and then separate the end from the can and replace the cartridge filter inside. I unbolt it from the side of the trans, bracket & all. Be careful with the 90 degree rubber elbow hose at the rear of the canister that connects to the trans case - that hose is a different size on each end and not easily acquired. This filter is the suction side filter going from the trans case to the 2 hydraulic pumps, be careful not to allow any debris to get to the pumps when servicing this filter assy.
Skip Marcy,
Thanks so much for your reply to my question. You answered exactly what I needed to know.
Thanks again.
Hillborne
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2022 BARFORD TR8036 MOBILE SCREEN (A51242)
2022 BARFORD...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
