Changing leg hydraulic filter on mahindra 4110. Tractor
   / Changing leg hydraulic filter on mahindra 4110. Tractor #1
Hillborne
Princeton, ma.
Mahindra 4110
unless you pull off the rear tire there is no way to get the metal case out-- unless you can take the two bolts that hold the plate in which the metal case is attached. Has anyone tried removing the holding plate?
Thanks
   / Changing leg hydraulic filter on mahindra 4110. Tractor #2
If you're referring to the large metal canister suction filter under the right side, yes, you remove the whole canister out from under the tractor and then separate the end from the can and replace the cartridge filter inside. I unbolt it from the side of the trans, bracket & all. Be careful with the 90 degree rubber elbow hose at the rear of the canister that connects to the trans case - that hose is a different size on each end and not easily acquired. This filter is the suction side filter going from the trans case to the 2 hydraulic pumps, be careful not to allow any debris to get to the pumps when servicing this filter assy.
Skip Marcy,
Thanks so much for your reply to my question. You answered exactly what I needed to know.
Thanks again.
Hillborne
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
