Changing leg hydraulic filter on mahindra 4110. Tractor
   / Changing leg hydraulic filter on mahindra 4110. Tractor #1
Hillborne
Princeton, ma.
Mahindra 4110
unless you pull off the rear tire there is no way to get the metal case out-- unless you can take the two bolts that hold the plate in which the metal case is attached. Has anyone tried removing the holding plate?
   / Changing leg hydraulic filter on mahindra 4110. Tractor #2
If you're referring to the large metal canister suction filter under the right side, yes, you remove the whole canister out from under the tractor and then separate the end from the can and replace the cartridge filter inside. I unbolt it from the side of the trans, bracket & all. Be careful with the 90 degree rubber elbow hose at the rear of the canister that connects to the trans case - that hose is a different size on each end and not easily acquired. This filter is the suction side filter going from the trans case to the 2 hydraulic pumps, be careful not to allow any debris to get to the pumps when servicing this filter assy.
Skip Marcy,
Thanks so much for your reply to my question. You answered exactly what I needed to know.
Thanks again.
Hillborne
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2019 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2019 CATERPILLAR...
1986 Diesel C70 Grain Truck (A50514)
1986 Diesel C70...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
