changing HST fluid
   / changing HST fluid
Well I think I found the Hydraulic strainer on my B2620. It is actually on the right side next to the hydraulic filter, bolt head facing down. Looks to be in front of an inlet or outlet hose. No mention of the darn thing in the manual. Since I already changed my fluid and got all bent out of shape about it, with industry wide proclamations:eek:, I am a little leery of removing and cleaning it now. Has anyone done this and do you loose much fluid? Thanks
   / changing HST fluid #24
bstrom,
On my BX the strainer is horizontal, not sure about your B. I suspect you will lose all the fluid as the strainer is in the bottom of the trans. Unless you could plug the hole quickly? Rubber stopper or something. In any case, good luck.
Matt.
   / changing HST fluid #25
I'd leave it at this point and catch it next time around. It's not like it's gonna clog or something and if it caught stuff it will stay caught. You know it will be clean if you take it out.
Yeah, I will probably do that, especially if it won't clog or anything. I'm not ready for another 4 to 5 gallon mess. I don't know for sure if it is the screen but it sure looks like it could be.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51242)
2021 HAMM HD+9I VO...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
John Deere X740 Mower (A50514)
John Deere X740...
