changing HST fluid
   / changing HST fluid
Well I think I found the Hydraulic strainer on my B2620. It is actually on the right side next to the hydraulic filter, bolt head facing down. Looks to be in front of an inlet or outlet hose. No mention of the darn thing in the manual. Since I already changed my fluid and got all bent out of shape about it, with industry wide proclamations:eek:, I am a little leery of removing and cleaning it now. Has anyone done this and do you loose much fluid? Thanks
   / changing HST fluid #24
bstrom,
On my BX the strainer is horizontal, not sure about your B. I suspect you will lose all the fluid as the strainer is in the bottom of the trans. Unless you could plug the hole quickly? Rubber stopper or something. In any case, good luck.
Matt.
   / changing HST fluid #25
I'd leave it at this point and catch it next time around. It's not like it's gonna clog or something and if it caught stuff it will stay caught. You know it will be clean if you take it out.
Yeah, I will probably do that, especially if it won't clog or anything. I'm not ready for another 4 to 5 gallon mess. I don't know for sure if it is the screen but it sure looks like it could be.
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2001 JOHN DEERE 8410T TRACTOR (A51243)
2001 JOHN DEERE...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
