Changing coolant yearly or lack thereof.
   / Changing coolant yearly or lack thereof. #1
GeneV
Elite Member
Lake County, IL
Bradley 48" stander MF GC1710
So, found something interesting today. I changed coolant last year on my GC1710, used this stuff:
I had no intention of changing coolant this year, not as though the tractor is a daily driver or anything. Anyways, today I stumbled on my el cheapo coolant tester, so since it's in my hand, why not. Tested the coolant and found this:
I thought maybe there's a problem with the tester, so tested some of this same coolant leftover in the container, and got 3 balls floating from that (safe to -10 deg). So yeh, this is surprising, and looks like I'm changing coolant this year after all.
   / Changing coolant yearly or lack thereof. #3
Aside from the jug that you showed compared to the fluid is the wrong color, what are you trying to prove/say?
Myself, I am going with whatever you are testing is not the STP Heavy Duty.
   / Changing coolant yearly or lack thereof. #4
I only trust a refractometer anymore,not those hydrometers.
For the Kubota's I mix green coolant 50/50 with distilled water.
   / Changing coolant yearly or lack thereof. #5
I have two cars here I drug out of the woods. 1964 Ford galaxies. Thunderbird 390 engines. Last drove in 1972. Antifreeze still good in them.
   / Changing coolant yearly or lack thereof. #6
I switched to pre mixed coolant about 20 years ago, it’s rated for 5 years or 150,000 miles
   / Changing coolant yearly or lack thereof. #7
Why are you only getting -10 out of 50-50 stuff out of the jug?
   / Changing coolant yearly or lack thereof. #8
I have found that the new coolant types don't have the same specific gravity of the old antifreezes and therefore doesn't work well with the older testers. Try it with a new tester designed for the newer coolants.
OMG, you figured it out, my post is a big lie! :rolleyes:
These are good points, fellas. Maybe it is the tester too, will pick up a new one at TSC today. In any case, looks like a year in the radiator degraded the coolant, which is strange.
2007 FREIGHTLINER 120 CLASSIC (INOPERABLE) (A55745)
2007 FREIGHTLINER...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
PREVIEW DATES AND TIMES (A54865)
PREVIEW DATES AND...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
16 T/A  TRASH TRAILER (A55745)
16 T/A TRASH...
