oldnslo
Super Member
Tree grower
Is the current system direct drive from the motor to the chipper? If yes would the existing bearings allow using belt drive vs gear box? Might be a little less costly and possibly belt slip would help reduce over torque to your chipper.
To add electric start with battery charging capabilities to your B&S motor would probably require adding charging system. These components if available could get expensive. Some items that might be required are: stator, voltage regulator/ rectifier, possibly even different flywheel if your existing one does not have the magnets for the stator.
If not having the battery charge is not a problem then the electric start might be an option. Look closely at your engine by the flywheel shroud. Does the shroud have a bump out area to accept a starter? Is there a mounting surface on the engine block for a starter in this area. Does the flywheel have the ring gear for a starter? If yes to these questions then for a couple hundred dollars you might be able to add 12 VDC starter option, if no the starter will probably not be an economic option.
