Chipper Change from small engine power to PTO for chipper shredder
   / Change from small engine power to PTO for chipper shredder #11
Tree grower
Is the current system direct drive from the motor to the chipper? If yes would the existing bearings allow using belt drive vs gear box? Might be a little less costly and possibly belt slip would help reduce over torque to your chipper.
To add electric start with battery charging capabilities to your B&S motor would probably require adding charging system. These components if available could get expensive. Some items that might be required are: stator, voltage regulator/ rectifier, possibly even different flywheel if your existing one does not have the magnets for the stator.
If not having the battery charge is not a problem then the electric start might be an option. Look closely at your engine by the flywheel shroud. Does the shroud have a bump out area to accept a starter? Is there a mounting surface on the engine block for a starter in this area. Does the flywheel have the ring gear for a starter? If yes to these questions then for a couple hundred dollars you might be able to add 12 VDC starter option, if no the starter will probably not be an economic option.
   / Change from small engine power to PTO for chipper shredder #13
Tree grower,
Are you also spinning the chipper while trying to start the motor is is there some form of clutch between the engine and chipper? If no clutch the electric starter may not spin this over either.
   / Change from small engine power to PTO for chipper shredder #14
I have an MTD chipper shredder w/ 10 HP BS engine. Compression is too great for easy pull start, so would like to modify power input to PTO on my Ford 1210. Two main issues--BS motor is 3600 RPM, PTO is 400-540, and PTO turns opposite direction of BS motor. Ideally I need a 6:1 gear reduction (increase) box that also changes direction of rotation. Somebody out there must have tried this. Would like to hear from anyone with recommendations.
I had this 5hp hard starting chipper/shredder. I took the pull-rope assembly off and chucked up a deep well socket onto a cordless drill and started the engine with it. Don't try it with an impact driver. Make sure to remove the socket and drill as the engine begins to fire or they could go flying.
   / Change from small engine power to PTO for chipper shredder #15
I haven't checked this engine, but I would expect it to have an automatic compression release for easier starting.
I have a 13 hp Chonda driven belt drive chipper, and yes it takes some pull because there is no disconnect. However I would expect an electric would be capable of starting it. Perhaps something like this but you may need a ring gear kit
Starter Solenoid Kit For Briggs & Stratton 693551 Air Cooled 7-18 HP Engine | eBay
Just an example, you would need to check your model numbers, many kits available
Briggs and Stratton starter flywheel ring gear kit 392134, 399676, 696537 | eBay
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2008 Ford Ranger Pickup Truck (A55852)
2008 Ford Ranger...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
