Chainsaw Scabbards - table
/ Chainsaw Scabbards - table #1
GuglioLS
Edgewood, NM USA
Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
My Wife and I cut firewood for us to keep warm by the fire in the winter.
We use the Jinma tractor & our ATV to climb a very steep hill on our property this gives us access to our forest. The woods is way over grown and also has lots of dead down trees as well.
I use the Jinma to pull the trailer and my wife uses the ATV to get up the hill with all the saws, gas, oil, tools & refreshments.
Trouble was, we take 3 saws and there was no good room for them in the ATV trunk. When we had the trailer loaded up with wood there was no room in the trailer for the saws.
So this leads me up to how I solved the problem.
I took some 1/2" scrap plywood I had that was taking up room in my shop and cut it up to make these Chainsaw Scabbards.
Then I got the bright Idea as to, well why not make the scabbards a little table to set the saw on so I could gas & oil them up as well as tighten and sharpen the chain.
So rummaged around and found some old door hinges.
Here is the result:
Now that seems to work pretty good.
But then I have to figure out how to support the scabbard so that it can be turned into a table.
here is what I did:
If one works that good, then three of them would be aw-sum. Then build a little box for the gas & oil while your at it.
So there you go, this was yesterdays Saturday afternoon project. It took me about 4 hours total. And solved years of frustration and future spilled bar chain oil cleanup from inside the ATV trunk.
/ Chainsaw Scabbards - table #4
Great looking invention.I think I will make something like that to hold mine on the tractor, I have been known to set the sqaw down and back over it.:eek:
Al
/ Chainsaw Scabbards - table #5
Any problem with the ATV, coming down that steep hill, when the trailer is full of wood? I've got a smaller trailer for my ATV and often wondered if I could manage a bigger one with all the hills on my property.
Like the saw racks. May do one on the box one the back of my ATV.
It's been REAL scarry coming down that hill on the ATV with the trailer loaded. I once weighed all the wood in the load on a bathroom scale a few logs at a time. It weighed in (just the wood) at 1100 pounds. The ATV is rated to pull 1200 - of cource this is on a flat surface. I don't use the ATV to haul down the wood anymore I think my luck doing that was goint to run out real soon. I now use the 4WD tractor to haul down the wood. I still use the ATV and trailer to haul down a full load of wood chips and that is not scarry.
The trailer is about 4'x6' with 16" sides. We load it way over the top.
If you have good solid firm packed ground you would be supprised how well it handles going down hill. In my case the path we us for going up / down is now loose dirt with tons of loose scatterd rocks. So it is not very sure footed anymore. The tractor does not slip a bit and weighs about 4500#'s as compared to the ATV @ 800#'s. When I use the tractor I don't even feel the trailer is attached let alone fully loaded with 1100#'s of wood.
Bedlam said:
Great looking invention.I think I will make something like that to hold mine on the tractor, I have been known to set the saw down and back over it.:eek:
Al
Al,
Thanks for the compliment. I have destroyed two cordless phones by placing them on top of the rear tractor tire then driving off and crushing them into the ground. New rule to self, nothing gets placed on the tires, period, not even for a second not even my gloves.
Backing over a saw, now that's not a good thing, not at all.
/ Chainsaw Scabbards - table #8
Gug,
Like I said, great stuff you do....
Al
I left them in the bucket and "scooped" on the way up to the saw site... then dumped...guess what? Not good.
/ Chainsaw Scabbards - table #9
Very nice project Larry, something alot of us need. I'll be looking into that myself.
/ Chainsaw Scabbards - table #11
I was lucky with my saw when I drove over it, it just broke the decompresser button.
And I have also set the saw in the bucket, scooped some dirt, and then dumped it and almost dackgragged it.:eek:
/ Chainsaw Scabbards - table #12
GuglioLS said:
Al,
That is a great project. I have been playing with a similar idea for my PU racks (also run 3 saws). Haven't done it as I like to stop for breakfast on my way to my wood patch. Those saws hanging there in plain sight would be a bit too much of a temptation I am afraid.
My tool box, gas and oil all ride in a plastic milk carton. Just the right size if you only mix a gallon at a time of mix.
Setting stuff on tires reminds me of how I learned not to set stuff on the top of my big step ladder when I was building an additon. It only took me twice of getting bonked by my hammer before I learned. Yep, I am a bit slow!
Harry K
/ Chainsaw Scabbards - table #13
Harry K
Harry,
the hammer story reminded me building the pier in my pond.
I waited for the ice, made a hole and hammered posts in. Than I went on with cutting a notch for the cross beam using saw and an axe. Well, I didnt want to leave the axe on ice - put it in the top of the post - and kept on cutting a notch with the handsaw. The shaking of the post losened up the ax and it fell on my head - not sure which end first, but since it made a hole in my hat and the skin too I think it was the blade what hit me.:)
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
