Chainsaw bar oil question
/ Chainsaw bar oil question #1
PhilNH5
Platinum Member
SE NH
Kubota B3000HSDCC
Folks,
I am hoping someone here can help me. I have a Stihl 025C chainsaw. Over the weekend I took the chain off to flip the bar. Gave it a thorough cleaning as well. Put it back together and tested it out. The chain was not throwing oil as it should. Stopped it and both the chain and bar are well oiled. Fire it up again but still not slinging oil off.
Today I read the manual and took the bar off again. Cleaned the oil hole though it wasn't dirty nor blocked. Test run gave the same results. Well lubed chain and bar but nothing flying off the tip like it should.
Any ideas or suggestions? I haven't cut with it yet as I am worried about the bar oil issue.
Thanks, Phil
/ Chainsaw bar oil question #2
I just bought a new 025 about 3 months ago and mine doesn't look like it's throwing oil like I think should or like my old Mac 10-10 but as long as the chain is wet and not dry and overheating it's OK. The 025 does not have an adjustable oiler like I am used to which bothers me a little bit but it cuts fine. I only use bar oil in it not 30 wt motor oil.
Mike
Mike,
Thanks for the reply. That is good to hear. In my mind I was comparing my 025C to the Poulan I replaced it with. The Poulan really sprayed the bar oil. The 025C isn't flinging any.
I will give it a test in some wood tonight and keep an eye on the temperature.
Phil
/ Chainsaw bar oil question #4
I also have the Stihl 025C. The carburetor also has no adjustment other than idle. These saws are designed to run cleaner to help conserve the environment. Might as well get used to it because all machines will be like that some day. Stihl is even making a four stroke engine now for some of its tools for even cleaner running. My saw works great. /forums/images/graemlins/grin.gif
/ Chainsaw bar oil question #5
PhilNH5
I've had my 025 for over 10 years. The oil has never really flown off the tip like the manual says. I have also never had any problems with it either.
Solo
Craig and Solo,
Thanks for the replies. Makes me feel better knowing othe 025s run this way.
Phil
/ Chainsaw bar oil question #7
I don't have a Stihl, but I have a Husky. Oil never comes off the chain, and if it did, I'd bring it in for service. I don't want to be squirting oil on the ground while I'm cutting wood. That would be just one more (little) souce of pollution. I think your saw is working the way it's supposed to.
Rich,
My Poulan did and according to my Stihl manual the 025C should as well. The manual tells you to point the tip at a piece of wood and you can see the oil. This is suppose to be a check that the oil pump is working OK.
But even if it is not being flung off the bar the oil is going some where. And yes it is a source of pollution. That is why the manufacturers have started offering vegetable oil based bar lubricants. Stihl calls their product BioPlus.
Phil
/ Chainsaw bar oil question #9
Phil,
Great question! I just bought a new Stihl also and was concerned about that very thing. I read the manual where it shows (including pictures) how to check to ensure that the chain IS throwing oil. I was a little concerned also, but this thread has eased some of that. In any event I did use the saw extensively after that /forums/images/graemlins/crazy.gif anyway.... and I kept checking the chain all the time to ensure it was ok.
Kevin
/ Chainsaw bar oil question #10
I have an O-66 Stihl which has the oil rate adjustment. I don't believe the O-25 has such an adjustment. Are you using generic chain bar oil like at Walmart or the Stihl oil? (they are way to expensive for me too) If not enough oil is being applies for your liking; I would think the only other choice would be to use a slightly thinner oil which would flow faster. You should be OK with what you have I think. As long as the bar and chain are getting a reasonable amount and nothing is getting hot.
/ Chainsaw bar oil question #11
<font color="blue"> Oil never comes off the chain, and if it did, I'd bring it in for service. I don't want to be squirting oil on the ground while I'm cutting wood. </font>
What I don't like about my Stihl 025 is that is has neither an adjustable oiler (like my old Mac 10-10) or a manual oiler. If you are cutting green wood neither is needed. However if you have to remove an old dried stump or something similar you will need that extra oil to lubricate and cool the chain. An RS chain runs about $25 I would rather put a little more oil non the ground than buy another chain. I only use Stihl or similar bar oils they have additives that make them "sticky". It's the same logic as you don't use outboard motor oil in weadeaters or vice versa if you do you will eventually get to buy and new outboard or a weedeater. I got lucky I only had to buy a weedeater.
Mike
Folks,
Thanks for the replies. We had rain again so I have not tested the saw. But I don't think it is something I am going to worry about based on what has been written.
The Saw is 2 years old and has been through maybe 6 cords of wood. I sharpen the chain w/ each tank of gas. I flip the bar when I remember to. It has been a really good saw for my needs. As I get older I can't remember things as well so I don't really know if this saw ever threw oil. But the poulan sprayed a lot of it and that is what I am comparing it to.
Chief,
I am using Poulan bar oil. Still have 2 qts left from the old saw. That is all this saw has ever seen. If this weekends test cutting is problematic I will try some Stihl oil
Phil
/ Chainsaw bar oil question #13
I think I have had about 10 different chainsaws over the past 30 years and no two were alike in the
bar oiling department. The Mac 10-10 had an automatic oiler as well as a manual one, which was nice
in heavy cutting. The first Mac I had only had a manual oiler some times I would forget to hit the oil
lever, the automatic oiler was a nice feature.
The old rule of thumb was a tank of oil to a tank of gas. I have noticed the newer Husky's I have use
about 2/3 oil to a tank of fuel, bar and chain life is normal. I do have to look close to see any oil sling with
Husky's.
Randy
/ Chainsaw bar oil question #14
PhilNH5, try that or maybe try thinning out the current oil a bit with some kerosene or diesel. Not too much or you might have a mess. I have my eye on an O-26 pro for my next sister saw. That O-66 gets mighty heavy after several hours and is lots of fun limbing with it. I have a Homelite Super 2 my Dad gave me to limb with but I can cut faster with a hand saw than that thing can. /forums/images/graemlins/crazy.gif
/ Chainsaw bar oil question #15
I've a small Stihl, and a larger Sears. The former does not throw oil (the oil reservoir empties about a third as quickly as the gas tank, i.e., fill oil about every third time one fills the gas tank), but the latter does (fill oil reservoir every other gas tank fill). I use Stihl brand oil, and the saw is only a year old. Used to worry about such, and cleaned out the oil nozzle, etc - seems the Stihl is just more economical with oil, and environmentally friendly.
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
Massey Ferguson 285 Loader Tractor (A66285)
Massey Ferguson...
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2017 Case CX145D (A60462)
2017 Case CX145D...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
