Chains Chains or Straps??
/ Chains or Straps?? #11
<font color=blue>...be careful with that 10 year old strap.</font color=blue>
Yeah, I hear you. My heavy work on the property is behind me now. I mostly just use it to pull up briar bushes. If I could just get time to make one of those nifty tree pullers!
Thanks for the word of caution!
/ Chains or Straps?? #12
i use both, depending on the job. the straps i have i got from a heavy equiptment rigging co. they were used to lift things with a crane, so i figure they are ok for my use.
/ Chains or Straps?? #13
I have several 3/8 chains that I pull everything with. Pulling a sump 700 feet will wear anything you use. If you buy hardened chain, big bucks, they will last much longer and I doubt you could break one with a compact tractor.
I had one lifting sling, my son left it some where, but I would not want to pull anything where it might drag in the dirt, especially with something heavy on top of it.
It is easier to shorten up a chain and they never get knots in them you can't get out. /w3tcompact/icons/smile.gif
Randy
/ Chains or Straps?? #14
I use chains, got a couple as a bonus at an auction. Was biding on some old ammo cans, misc contents mostly old pipe fittings, got 10 of them for 2 bucks apiece. 2 of them had nice 3/8 chains in them. Never tried using straps.
/ Chains or Straps?? #15
I use a 5/8 choker cable. Very easy to hook up around your load, but more importantly, it is very easy to un-hook from your load. Much easier for towing logs around than chain or straps. Maybe them logger are onto something. /w3tcompact/icons/wink.gif
/ Chains or Straps?? #16
Based on my safety experience in heavy industry ... I'll stick with chain. The problem with slings / straps is that none of us are rich enough to treat them as they're treated in commercial use .... if in doubt - toss 'em out!
Straps and slings are used in lifting applications because of the weight distribution, stretching ability and width .... but they have a pretty short life. Not because they will fail ... but because no one wants to take a chance.
Dragging is a completely different application. Fabric does not take kindly to abrasion. And those tied together straps will do the same kind of damage that a broken chain will when it comes apart!
Lifting ... well, slings - wire rope or fabric are preferred. Dragging - go chain go ...
/ Chains or Straps?? #17
I use both, but prefer the HD 3/8 chains. I have several of different lengths and connect them as needed. Use caution no matter what you do. Lots of horror stories out there.
/ Chains or Straps?? #18
For what you are doing I would stick with the chain. With a compact tractor you will never be able to break a quality 3/8 chain. I did stretch 1 so bad that you could pick it up like a piece of flatbar but that was using a 4020 JD with good traction.
/ Chains or Straps?? #19
<font color=blue>With a compact tractor you will never be able to break a quality 3/8 chain</font color=blue>
I was out roaming our property the other day and found "half" of a length of 3/8 chain. I'd like to say it was the result of my tractor but it was from a Case telescoping forklift pulling out a very stuck lumber truck.
I added it to my chain collection none-the-less /w3tcompact/icons/smile.gif
/ Chains or Straps?? #20
I have used both, but only trusted chain when the load was great. I have heard stories of chain recoil when broken, but I have to tell you, I have broken two chains , one 3/8, and one 5/16 when I logged my place , the 3/8 chain I watched break and there was maybe a 1ft. recoil- it snapped and dropped right about in the same place it was, the other I did'nt see and I did'nt hear , the dozer just broke free, the chain was also in about the same position. I don't think there is a great danger with chain unless maybe you were sitting right on it.
2019 Bobcat T590 Compact Track Loader Skid Steer (A59228)
2019 Bobcat T590...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
2007 Chevrolet W5500 20FT Dovetail Flatbed Truck (A59230)
2007 Chevrolet...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2015 Caterpillar Backhoe (A60352)
2015 Caterpillar...
