Chains on rear wheels only with inverted snowblower
   / Chains on rear wheels only with inverted snowblower #1
TractorTYMe
Flathead County, Montana
TYM T474 HST
Hi! Guys,
I am waiting on my MK Martin MB68 P/T inverted snowblower for next snow season, but my question is? Can I get away with chains on rear tire mostly. I take care of the ranch I live on with 6 houses on 30 acres. Mostly flat except the last part of driveway entering highway is pretty steep.
   / Chains on rear wheels only with inverted snowblower #2
I get 120-140" of snow a year and last year was my first year with a pull blower. 74" FarmKing pulled by LS 4140 cab with loaded turfs. No problems at all but all flat. If you do not have turfs, traction will be less and depending on how steep your one spot is, chains might be a wise move. If I had problems I was going to stud the rear tires. I have oversized turfs and putting chains on is a very poor option for me at my age.
I have R4 industrial tires. I figure I'll try H-style chains on rear's first before I determine if it is needed to equip the front's too? We average 100-120'' of snow just outside Glacier Park, we're close to the continental divide and get dumped on at times.
   / Chains on rear wheels only with inverted snowblower #4
I have R-1's on my Kubota M6040. Because of the weight - 10,010# - I have never needed chains - period. My M6040 has 4WD.
When - for whatever reason - the plowing/blowing gets tough. Do what I do. I have a valley in my mile long driveway. I use a rear blade to plow snow. If it's so slick that I can't pull up out of the valley - go to the top of the valley and plow/blow DOWN the hill into the valley. It may take a couple more trips but it avoids the need for chains.
If your tractor is not 4WD - get a good set of chains - front & rear.
I have a 7' rear blade available to take care of berms if the edge becomes bad. Yes my TYM T474 is 4wd. I know my ATV does REALLY well with chains all around, I can double the amount of snow I push with my 5' blade. Sometimes we get a few wet/freeze cycles that makes everything a sheet of ice.
   / Chains on rear wheels only with inverted snowblower #6
TYMNorsky - I have a large field that can thaw and drain down onto the road on one side of the valley in my driveway. This thaw/melt water will freeze on the road. This is the one condition where I plow from the top of the road DOWN into the valley.
I have cut a ditch to handle the melt water on that side of the driveway. Usually this will handle the situation. However - there are times when the water freezes/overflows/freezes and fills this ditch. Then the melt water runs down the driveway on that one side of the valley. Turns the driveway into a sloped ice skating rink. Fun & games..........
BTW - like your avatar. What did your dog think about the situation?
The dog was a picture of my spirit animal on how I feel most days anymore. Well back to snowremoval on sheet of ice, yes I did what you with my halfton truck plow. Plow downhill in most cases......and with a snowblower there won't be nearly the same weight to deal with either.
Here is the rig btw, 2019 TYM T474 48.3Hp
   / Chains on rear wheels only with inverted snowblower #8
With that mule and those rear fenders I hope you have 3 inches of clearance at the front edge of the fender as otherwise 4 link V bar chains will not work.
If the chains do not fit you will need to have the rear tires loaded and invest in a set of 4 link V bar chains for the front tires or invest in combine tires and wheels to make room for chains.
   / Chains on rear wheels only with inverted snowblower #9
I've never needed chains in the front for the hills around here. I steer with the brakes if needed and lock in the rear diff if a tire starts to slip.
I chose these H-pattern DUO239 7mm alloy chains for the rear since I have limited fender room on the front of the rear fender.
11 ft Shipping Container (A55973)
11 ft Shipping...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 Doosan C185 Trailer Mounted Air Compressor, Model 484289UBACG07, S/N C185WD20T4F, Deutz Diesel (A59076)
2018 Doosan C185...
WACKER NEUSON PD3 TRASH PUMP (A58374)
WACKER NEUSON PD3...
2012 UTILITY TRAILER MANUFACTURER FLATBED (CRACKED FRAME) (A58214)
2012 UTILITY...
FP Seedavator SB80 Seed Spreader Attachment (A55973)
FP Seedavator SB80...
