Chains instead of a top link for bush hog?
   / Chains instead of a top link for bush hog? #41
The geometry of that cutter is quite a bit different than the ones I have ran chains on. I can see where you were having the problems.
What brand/model is that cutter BTW?
My mower is a 6' Walco Whistler.
Shortly after I bought my (first) tractor in 2006, I was mowing an old grown-over field. Rounding a corner, I glanced back only to see the mower climbing the left rear tire! Thankfully, I got it stopped before totally destroying the tire (or hitting the cab!!). The problem turned out to be that the lower link arms were attached using bale pins, not bolts. A sapling stub or something must have hooked a pin out. Having a lift arm slip off its shaft allowed the mower to swing sideways enough on a turn to have a tire lug catch the edge of the mower deck.
My dealer replaced the bent parts for me and bolted the lift arms in place, so no further problems.
Someday I hope to afford installing a hydraulic top link, then the mower top chain tension adjustment will be even easier and I'll only have to dismount from the tractor at the end of the day!
BOB
   / Chains instead of a top link for bush hog? #42
i hear ya.. however I don't make a practice of nose diving into a ditch and mowing a 45' down and 45' up in a 5-6' wide trough.. :) .. which it sounds like some people are wanting to do.. or planning to do :) :)
soundguy
Neither am I, but I seen at least one picture of a TBNer backing up a pretty steep embankment.
   / Chains instead of a top link for bush hog? #43
When mowing pond levies and other embankments I back up and go down some really steep stuff, but I use the hydraulic top link to keep from stressing the equipment.
We also use a pull type that works really well for this.
   / Chains instead of a top link for bush hog? #44
Can't remember which TBN member's this is:
attachment.php
   / Chains instead of a top link for bush hog? #45
i bet them u-joints love that angle.. :)
soundguy
   / Chains instead of a top link for bush hog? #46
If you look at the PTO-shaft-to-gearbox angle & the PTO-to-PTO-shaft angle, neither seem all that extreme to me ... ?
attachment.php
   / Chains instead of a top link for bush hog? #47
   / Chains instead of a top link for bush hog? #48
If you look at the PTO-shaft-to-gearbox angle & the PTO-to-gearbox angle, neither seem all that extreme to me ... ?
attachment.php
Looks like a great way to save a set of lift arms. This method (chains) appears to be more forgiving...
   / Chains instead of a top link for bush hog? #49
THAT is exactally why I like the chains.
And I'll second that the driveline angle doesnt seem too extreme to me. The thing isnt a drive shaft. It is only spinning 540 RPM.
Look at the range of angles a PHD has to go through:confused2:
In a case like that picture, with the equipment on hand, I see no other way to cut that steep hillside. (maybe the OP doesnt have $3k to plop on a sickle). And cutting that hillside would be nearly impossible with a ridgid setup and a LOT harder on the 3PH and a-frame of the bushhog
   / Chains instead of a top link for bush hog? #50
soundguy
I agree that constant use at those angles would result in increased wear and a shortened lifespan of the U-Joints, but I doubt these U-Joints see more then a few minutes of operation at that angle during mowing. The U-Joint life might be reduced, but I'd guess they'd still last for several mowing seasons before replacement becomes necessary.
Just my opinion...
BTW, the recommended maximum angle for U-Joints is about 15 degrees and the articles I read that in were discussing pick up trucks with lift kits.
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2017 Ford Explorer AWD SUV (A56859)
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
