Chains instead of a top link for bush hog?
   / Chains instead of a top link for bush hog? #31
I'm not sure where a ridgid setup came into play. Did older top links not have a way to loosen them? I run with my very loose, but tight enough that I can still lift my mower. With it loose, my mower follows the contour of the ground just like the chains do.
What I'm confused about is why replace the top link or anything else with a chain that doesn't adjust or tighten up as easily at the top link does?
Eddie
IS your setup the one with the U-shaped bracket like pictured earler.
The ridgid set-up I am talking about (and like on my 306) is a set-up like a back blade would have. And like the one Rcokgod mangled. THOSE do not allow the mower fo follow the contour like a chain or u-link would
   / Chains instead of a top link for bush hog? #32
The U link is where I'm confused. I didn't realize that everyone didn't have one of those.
I'm still not a fan of chains, but can see where they offer more flex then not haveing the U link.
Thanks,
Eddie
   / Chains instead of a top link for bush hog? #33
Thanks,
Eddie
Yep, I have see a lot of cutters without that u-peice and also without chains. THUS the "ridgid" setup I was refering to. Which does NOT follow the terrain at all.
   / Chains instead of a top link for bush hog? #34
Yep, I have the flex link (I'm assuming you mean that "U" shaped bracket at the implement's upper connection), but even they can be a limiting factor at an abrupt transition such as the top and bottom of a ditch.
BTW, I use a standard upper link piece...I'm just adding one limitation of those links used with a flex or slotted implement link.
i hear ya.. however I don't make a practice of nose diving into a ditch and mowing a 45' down and 45' up in a 5-6' wide trough.. :) .. which it sounds like some people are wanting to do.. or planning to do :) :)
soundguy
   / Chains instead of a top link for bush hog? #35
i hear ya.. however I don't make a practice of nose diving into a ditch and mowing a 45' down and 45' up in a 5-6' wide trough.. :) .. which it sounds like some people are wanting to do.. or planning to do :) :)soundguy
I can understand your position but my 38 acres in New Hampshire has more elevation change than 95% of the entire state of Florida. :D
I like Electrarc's chain on the backstays. I have rigid backstays and the U shaped piece on the A frame doesn't have quite enough range for everywhere I mow. I'm thinking that slotting the backstays for about 6" of travel might be just the ticket.
Soundguy, You've got the most mowing experience that I know of on TBN. Have you actually ever had a mower kick up enough to be dangerous to the operator? MikeD74T
   / Chains instead of a top link for bush hog? #36
I suspect that Farmswithjunk might have more mowing time (although rumor has it that as one of those highfalutin money grubbing business owners, he doesn't get much seat time anymore :D :p :D)
Aaron Z
   / Chains instead of a top link for bush hog? #37
I suspect that Farmswithjunk might have more mowing time (although rumor has it that as one of those highfalutin money grubbing business owners, he doesn't get much seat time anymore :D :p :D)Aaron Z
I'd be happy to hear from Farmswithjunk or any others as well as long as it's experience not opinion. MikeD74t
   / Chains instead of a top link for bush hog? #38
OK...Here it is....You asked for it!
The tractor/mowers I use in the commercial end are mostly pull type bat wings. However, I do have a couple smaller mounted mowers we use essentially as "giant weed eaters" in confined areas. They have hydraulic top links, and what i like to refer to as "toggle links" (flexible top link mounting points) Their configuration allows great flexibility. Mow where we mow and you really need that.....Getting down into ditches, around culverts, and in some VERY awkward spots, I've seem mowers 45 degrees up or down from level with the tractor. No, I don't want that on a regular basis, but it happens...
Now, on to what I use "at home". My property is partially level hay fields, and a good bit of hilly, choppy, steep creek banks, woods, and roadside ditches. By this point in my life, I've had all the fun I want with using weed eaters and such. I mow EVERY blade of grass/weeds I can with a mounted rotary cutter. Most people would have a panic attack watching me mow. I've put tractors into positions where the faint of heart wouldn't dare. To achieve that end, I've ran without a top link at all on occasion. I've used chain top links, and I've replaced sections of the rear struts (from rear of mower deck to top link mast structure) with chain to allow the top link "A Frame" to fold back when needed. About 50% of the mowing I do on my place (other than the hay fields) requires me to adjust the mower to where the tail wheel is still on the ground when the 3-point hitch is all the way raised.
For the record, when using NO top link OR when using a chain as a top link, I've NEVER seen the mower "kick up" when the leading edge hit an obstacle. That "theory" is just that....a theory.....One that just doesn't seem to exist in real world FACT. Anything is "possible", but I'm not changing my way of doing things based on a theory that is seemingly unheard of in real life.
The single greatest "safety device" that can be installed on a tractor is a SAFE, EXPERIENCED, REASONABLE OPERATOR. Without such, NO device added or left off will prevent accidents. WITH such, most would truly be amazed at what you can do with a tractor and mower.....
And yes, I'm basing my opinion of tens of thousands of hours of real world application.....not just a few hours in the seat and a theory.
   / Chains instead of a top link for bush hog? #39
I think I'd get a semi-mount mower with hyd tailwheel then.. if it is that up and down.. :)
I think the other poster nailed it. FWJ has a mowing business.. lots more mowers and time under him than I do.
I've never had a mower kick up on me, but then I use a toplink too, and try not to hit too many stumps.. :) . my mowers all have flex links on them, or i'm using a semi-mount, or a pull type batwing. ( ant mounds? now baby.. I can mow some ant mounds! ants fear me.. ;) )
I have re-welded a deck for a buddy that had a mower near shell out from hitting a stump. bowed the front of the deck in, eventually ripped one side lift pin off the a-frame, and bent the pto shaft as the mower DID kick up, however to my knowledge it did not kick up and fold completely over, IE.. hitting hte operator or back of the tractor.. flipped up enough to eat the pto shaft, bend the afram.. or torque it, and then it all gave loose when a 3pt pin went. it was a beater mower so we used a jack and chain and got the front un bowed.. thru another pto shaft on it from a donor, used a long bar and re bent the a-frame, did some welding, then he cleaned the seat on the trsctor real well and off he went :)
so no.. never had one flip up and over.. obviously have seen one that did rise up and bend a few things.. etc. I told my buddy to stop mowing stumps.. :)
soundguy
   / Chains instead of a top link for bush hog? #40
GREAT POST :thumbsup:
2003 Big Tex 10PI...
2013 International Derrick Digger Truck (A55973)
2013 International...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2019 INTERNATIONAL...
2014 Mazda CX-9 Sport SUV (A56859)
2014 Mazda CX-9...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
