CHAINED UP!!!!!!
/ CHAINED UP!!!!!! #31
Better to long than to short! It a good idea to leave a couple of the side links extra. If the extra "loose" links clang on the fender just tie them out with a plastic cable tie.
As in most things, you get what you pay for. I looked a the net for chains also. Ended up buying through NAPA. They can get tire chains from Security Chains. The cost 75 buck more but fit like a dream., Although a bit of a pain to put on, the chains weight about 70 lbs per side!
Derek
/ CHAINED UP!!!!!! #32
The front chains just barely clear the steering arm and adjusting knuckle. Only a little paint has been knicked off the steering arm (the big plate)) -whew.
When I put them on, I installed the chains extra tight and used some wire to pull the locking arm closer to the tire. In hind-sight, I think I can expend muscle ess energy if I remove 80% of the air pressure from the tire before I mount the chains. Then adding air pressure should make them fit nice and snug-w/o the hard part of setting the locking arm.
I have put about 5 hours of tractor time on them and everything is going well. I am quite pleased.
Peter
/ CHAINED UP!!!!!! #33
I looked at a 2410 and 2910 on a dealer's lot and the 2410 steering arm is MUCH farther away from the front tire/rim than on a 2710/2910. I suspect the B2400 that you have is more like the 2410. With R4 tires on a 2710/2910, there is literally only about 3/4" clearance between the tire/rim and the arm. It's incredibly close.
For those with 2710/2910 models, don't jump to the conclusion that you can use front chains because they can be used on a B2400 like PKS has. Unfortunately the clearances are quite different.
I got a front set of chains for my 2910 from BB chain and there was no way at all that they would clear the steering arm. I asked about lighter gauge chain and they felt lighter chains would just break and that I'd be wasting my money. So for now, I'll see how I make out with just rear chains.
I'd love to hear how others make out.
Peter
/ CHAINED UP!!!!!! #34
Put my rear chains on last night. Just did a quick fit and with no instructions I got them on in about 15 minutes per tire. I'll take them off and tweak them a little for a better fit but I'm happy with the results so far. Not easy as the links are all 3/8" and each set weighs about 45lbs. I thought the $162 price tag was pretty reasonable too.
/ CHAINED UP!!!!!! #35
For what it's worth, I bought chains last year from Tirechains.com for my TC21D and I thought the service was great. I got the chains within 48 hours and the total price including shipping what cheaper than I was quoted from the parts store. I had to cut the chains to length but the whole process of fitting them only took about 45 minutes and that was cutting the chains with a hacksaw. And now i've got 4 spare cross links in the tool box.
How close do you think they should supply the chains to the length you need, 1 extra link, 2 extra links? Thats not much to work when you consider how much the tire diameter can vary. Anything over 2 extra links your are going to have to cut off anyway, so they might as well give you a lot of extra chain.
Kelvin
/ CHAINED UP!!!!!!
I'm trying to post some pictures of the mighty Boomer chained up. Please bear with me if it doesn't work!!!!!!
2016 John Deer 5075E (A60462)
2016 John Deer...
2018 HINO SA (A58214)
ROSCO SPR-H CHIP SPREADER (A59823)
ROSCO SPR-H CHIP...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2016 Ford Fusion AWD Sedan (A59231)
2016 Ford Fusion...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
