Chain
/ Chain #42
I find chains easiest to work with overall dragging trees. But I'm mostly dealing with medium-sized pines.
/ Chain #43
Do many of you have hooks welded onto the front end loader ?
This is how mine are - just basic 5/16" weld-on grab hooks. Other than a 3rd in the middle maybe, I wouldn't want any other way.
IF you're interested, the toothbar is this: Amazon.com: Titan 72" Bucket 23TF Tooth Bar Universal Size Skid Steer Tractor USA Made: Home Improvement Required some slight fitting with an angle grinder at the edges for clearance at the bucket weld seam (grinding on the bar, not the bucket :) ) Decent for an inexpensive piece.
/ Chain #44
What size are the hooks? What are they called, so I can search for them? Thanks!!
We call them "Forest" hooks, they are very popular with the the logging/skidding people since they do not snag on things.
/ Chain #45
I'd say most guys do, some get dealers to weld them on, some weld themselves, and many buy or Bolt-On ones. We have a few options for hooks, shackles, and rigging accessories.
/ Chain #46
Two main style of chain hooks are "Grab Hooks" or "Slip Hooks"...
Grab hooks are sized according to chain size.... 5/16 chain, 5/16 hooks.... 3/8 chain, 3/8 hooks... It all (basically) about slot size of hook...Clevis pin usually is match for chain and slot size...
Slip hooks are usually sized by size of clevis pin (according to chain link size).... You are not going to put a 3/8 pin through 1/4 inch chain...
Do GOOGLE IMAGE search for "chain hooks", you will be amazed what is out there...
Dale
Pictured was neither a grab hook or slip hook. I know that hook will slip, but looks like it's less likely to come unhooked than a slip hook. That's why I asked what it's called.
I will just search Amazon for "hook"
/ Chain #47
/ Chain #48
Those C-hooks work great. I pulled up a bunch of old locust posts over the last few weeks using one. Just a couple quick wraps around the post with the chain, slide the chain through the gap of the hook and pull up with the loader. The chain never slipped or come loose, not one time.
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2021 Bobcat T62 Compact Track Loader Skid Steer (A64553)
2021 Bobcat T62...
2022 EZ-GO ELITE...
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
