Chain storage
/ Chain storage #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
I've been using my 4210 drawbar hitch and a chain to pull stones and tree trunks around and got tired of unhooking the chain from the clevis after every use, and storing it in either the FEL bucket or on the platform. I had this old Craftsman poly GTO toolbox with a broken latch, and the lower section is 15 inches long and the width and height are 7 1/2 inches. With the drawbar fully extended this size box fits EXACTLY in the space below the PTO shaft and the holes in the bar are ideal for securing the toolbox. With a 1/2 plywood floor in the bottom of the box it still holds 50 to 75 feet of 3/8 chain and I don't have to waste time unhooking the chain after every pull.
/ Chain storage #2
JD
Thanks for the tip. Seems like a good one, and will look into that as a fix for carrying chain.
/ Chain storage #4
I'm with Stuart, post a photo. It sounds like a good answer to the problem. I've lost a couple of chains because I threw them into the FEL and forgot they were there. One I never saw again, I think I buried it, the second one I "found" with the bush hog.
/ Chain storage #8
I do not have it mounted. I carry it along when needed. It is kinda large. I suppose you could drill a couple of holes or weld a bracket and fasten it to the tractor where ever space permits. Welding is probably better since it will keep the box waterproof.
/ Chain storage
I would have included a photo but I lent my digital camera to my nephew for spring break and he is in Florida right now...
/forums/images/graemlins/frown.gif
I'm not sure if the idea would work on other tractors which is why I posted it in the JD forum, I will get a pic posted as soon as I can.
/ Chain storage #11
This is what I did. I decided to go for the fender since there was no way to put it on the back below the ROPS with how big it was. On the rops would've been an option as it didn't interfere with seating or anything else but did obscure my vision if I wanted to look straight down at the implement.
I took off the grab handle and the seat belt keeper. I moved the seatbelt keeper to by the 4WD engangement handle on the side using an existing bolt. The grab handle I just left off.
I used those holes for 3/8" bolts along with 2 new holes. Fender washers on the fender side. I also inserted a few fender washers in between the box and the fender on the front bolt to account for the curve on the fender.
/ Chain storage #12
Hey Bill, Good idea /forums/images/graemlins/tongue.gif
Maybe I should be using the chains like you instead of bending my bucket on the rocks /forums/images/graemlins/ooo.gif
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
Generac QT02724 Anax Generator (A61572)
Generac QT02724...
EZ Trail 3400 (A63688)
LOT OF METAL GATES (A63291)
LOT OF METAL GATES...
Unverferth 432 (A64119)
Unverferth 432...
