Hendey T&G
Will chains listed as fitting 14.9 x 24 tire, fit on a tire marked 16.9 x 24?
Thanks for any wisdom.
depends on the chains some are more oversize than others. You can definitely stretch them by adding links, really the only way to know for sure is to measure the length.After searching a bit, looks like 14.9s are about 7" shorter in circumference. Probably can't stretch 7" to make them fit.
I guess I could add a couple links for length.
Any thoughts?
These are used chains.
