Chain Saw Question
/ Chain Saw Question
Thanks for the suggestion. I have used my tractor to pull out a few larger stumps, which works fine. It isn't practical, though, for me to do that for the buckthorn, for a couple of reasons. First, there's the sheer magnitude of the infestation. When I was out cuttinig the other day, in about an hour, I cut probably 40-60 trees down. That would have taken me a couple of days using a chain to pull them out. Also, the way buckthorn grows can be an issue with using a chain. They often grow in "clumps" meaning there might be 5-8 trees, all growing from the same root system, all of them converging at their base. So, they might each be 2-3" in diameter, but the whole diameter of the clump might be 12"-18", and the root systems are too strong to pull with my SubCUT.
One thing the dealer did mention (if I didnt' already say this) is to use my FEL to bend and break the trunks in one direction, then come through with the chain saw and finish the job. This could prevent some of the twisting and pinching that is causing all the problems I am having. I am also wondering if I add a toothbar to the FEL, could I dig into the roots of these trees where there are maybe 100 1-2" trees for every square 20 feet--there are a few areas that are like that. So, if I remove the few larger trees by hand chain saw, I can leave those to the FEL. I don't plan on puttng the FEL on again until late summer, but I will try that then.
/ Chain Saw Question #83
I agree with AMR, I've also cut everything with my Stihl 026 and the only time the chain has ever come off is when the chain was way too loose. I have often use the saw to clear small brush. BTW I also have a trimmer with brush and saw blades, I use the chain saw to trim the small stuff it's much faster than the blades on the trimmer.
Something is not right with ProudestMoney's saw.
/ Chain Saw Question #84
Kevin, and everyone else, do you think it would help to change the length of the bar and chain? I was noticing in the manual that my saw can actually drive a 12", 14" or 16" bar and chain. I bought it with a 14". I was wondering if, given the small size of the stuff I am cutting, a 12" might reduce the chain travel back and forth inside the bar groove? Thoughts?
/ Chain Saw Question #87
If it runs good and the bar is straight, I think your dealer is probably right that the saw is OK, but I'm surprised he didn't check the sprocket. If that wore off to the side or somehow wrong, all sorts of funny stuff can happen.
Keeping your cut as close to the saw as possible does make sense; if you can hook them with the log jaws, you might reduce vibration significantly (except limbing out a tangled mess, I always keep cut right to the jaws, though not sure if it is proper technique). I also keep it wide open throttle all the way through the cut. Of course, it also seems that I try to bend smaller stuff, but I'm not really sure; I just go with what feels right at the time and seldom remember the exact technique. /forums/images/graemlins/blush.gif /forums/images/graemlins/wink.gif
Where, I don't agree with your dealer (remember, I'm just a DIY guy like you though), is in a wider pitch making things worse. No doubt it will be a bit more stress on the cut, but much more latteral strength on the chain. See if he has a loaner 230/250/270 with a .325 X .063 [with a sharp chain and good sprocket]. This would be the shotgun approach (unless he has a model with the quick tension): you'd have standard tensioning, closer links, thicker guides, and more sprocket teeth: the latter two I think would help significantly for your problem. Maybe he can outfit your saw with that size, but I know nothing of the quick adjust saws.
I don't think you'd make things worse going shorter on the bar, but don't think it's the problem either. /forums/images/graemlins/crazy.gif Good Luck! /forums/images/graemlins/smile.gif
/ Chain Saw Question #88
/ Chain Saw Question #89
With my narrow kerf chain, when the chain comes off its my fault and I have learned to try to keep this from happening.
You guys with larger saws and chains will not have that problem as much!
/ Chain Saw Question #90
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A60736)
2008 TEXAS BRAGG...
2019 F-550 Bucket Truck (A61307)
2019 F-550 Bucket...
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2018 DRAGON 150...
