chain rating
/ chain rating #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
I have some chain 3/8" has C7 marked on the links, any one know what the chain might be rated for? I have had the chains for 20 years and pulled about everything you could think of I never gave it much thought untill I started reading the forum. Also with all the talk about tying down a load on a trailer to meet the new D.O.T. requirements what about the safety chains on the trailer do they have to be rated the same as the tie down chains? I think I might need to add some larger safety chains to my trailer.
Charlie
/ chain rating #2
Markings of a C7 mean it is grade 70 steel transport chain. This grade 70 is sold for use as a binder chain. Sold new 3/8 grade 70 chain has a working load limit of 6600lbs. I do not know if this chain will meet the new DOT requirements. But I hope this helps.
Rob
/ chain rating #4
I think that 3/8 binder chain is ample for us in the compact tractor division. With most of the trailers that are on the market today that I have seen, if your tractor ever tried to leave the trailer it would take some trailer parts with it.
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
Landpride PL3048 (A64126)
Landpride PL3048...
213078 (A64276)
213078 (A64276)
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
John Deere 750C Dozer (A66285)
John Deere 750C...
