chain installation
/ chain installation #1
jam2004
central NJ
Kubota BX 2230
I recently ordered a set of rear chains from my dealer. I cut open the sack they came in and there was no manual included--just the chains. Any tips on how to install them on my 2230?
/ chain installation #2
Go to www.tirechains.com where there are instructions for installing various types of tire chains.
/ chain installation #4
Watch the clearance between the inside of the tires with the chains installed. You might need a spacer to get the appropriate distance from the chains to the fenders and other stuff. In the past, when I used to use chains, I would install the inside at the loosest possible position and then use shock cords as spreaders to take up the tension on the outside.
I am now running a 2200 with filled Ag tires and have not found the need for chains. Once the beast is in four wheel there is not too much that will cause wheel spin. I also run a weight box for blowing and or plowing.
Thanks sandyc. I guess you see a few inched from time to time up there.
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2016 Ram 5500 (A64127)
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
