Chain hooks
/ Chain hooks #1
sros990
West Virginia
JD 990
I will be getting a 300CX loader with my new 990 tractor this Spring and would like to know if chain hooks are a good idea. If so, I would like to know:
1. What kind of hooks should I get?
2. What size hooks?
3. How many hooks?
4. Where on the FEL should they be placed?
5. How should they be attached to the FEL?
6. Should I have the dealer attach the hooks?
7. What can I expect to pay?
In addition to the hooks, what size and length all purpose chain should I get?
Thanks,
Steve
/ Chain hooks #2
1. Steel ones /forums/images/graemlins/grin.gif
2. Size to fit your chain
3. At least 2 (one on each side), and another one in the middle doesn't hurt.
4. See above.
5. Probably welded on, although some have bolted them on. Which ever way you do it, make sure the bucket is strong enough or suitable reinforced to take the stress.
6. Depends on whether you think you can do it yourself. Anyone should be able to drill the holes and bolt hooks on if that is your preference. If you can weld, then it depends on your confidence in your welding skills.
7. The hooks themselves are cheap like dirt. Having someone else weld them on - don't know.
Here are the chain hooks I added to the bucket on my 990.
/ Chain hooks #3
Chain hooks are one of the most useful things you can add to your FEL. One at each end and one or three in the middle are my preference. I suggest you use 5/16 grab hoods (grab hook is the one with the narrower “slit” opening. The reason for a 5/16 grab hook is that you can slip a 1/4” or 3/8” chain into it. I know that sounds strange, but stop by the local hardware store, play around with the hooks and you’ll see what I mean. So, with a 5/16 grab hook, you can use ¼, 5/16 or 3/8 chains.
On my JD 770, I welded a ¾” x 5” flat bar underneath the top lip of the bucket for reinforcement. You see a lot of buckets with hooks welded in the middle that have bent down the top center section. For my JD 5420 bucket, I welded several support brackets underneath the center section of the top lip. The support ended up being about 2' long. I also welded bracing just underneath the hooks welded on the sides. For either installation, you can barley see the support plates welded up inside of the lip.
Grind the paint before you weld, sand the edges of the paint, spot paint the bare metal and flash the whole bucket with a glossy coat of JD green. Why don’t they just weld hooks onto the buckets from the factory? Sure would save us a lot of typing here.
/ Chain hooks #5
It may be a good Idea for you to have the dealer do it before delivery,maybe about $75Doing them yourself is great if you or a friend has a welder, if not go with the dealer and he will have all your answers and stand behind it also.
/ Chain hooks #6
</font><font color="blue" class="small">( Why don’t they just weld hooks onto the buckets from the factory? Sure would save us a lot of typing here.
)</font>
Well Said! /forums/images/graemlins/confused.gif
/ Chain hooks #7
I run a 420 FEL on a 4300 tractor, two days after delivery I welded a piece of 3" channel iron across the top of the bucket. Then welded loops to this so I could attach the hooks with clevises. That way I can change anything that gets damaged. Turns out I settled on a large slip hook because I could also use ropes and straps instead of chain as I frequently want to lift a load such as fridge or stove that I can't put chain on. I have short chains with grab hooks on one end and slip hooks on the other for hauling logs etc which I also use for lifting. The grab hooks make them adjustible for length.
/ Chain hooks #9
I welded a piece of angle iron across the top of my bucket and cut slots in it 16" apart. Works the same a hooks plus it stiffened the bucket up a bit.
/ Chain hooks #10
The angle might work but I always worry about the chain slipping out under load if the bucket is tipped. Also you need very thick angle to have enough strenght. IMHO
/ Chain hooks #11
That's what I like about it. If I want to take off the chain, for instance after moving a log and want to push it around, all I have to do is roll the bucket forward and back up. It's all about not having to get off the tractor. I use this setup constantly and never have had it come off when I didn't want it to. You have to roll the bucket all the way for it to come off. Definitely thick angle. I think mine is 3/8".
/ Chain hooks #12
A lot of great suggestions but one note of caution, when using a hook on one end of the bucket, make sure the load is not too heavy or you will twist your bucket, most use both hooks and center the load or use the center hook.
/ Chain hooks
Thank you for the great suggestions. I have a couple of follow-up questions: What grade grab hook should I get, and is additional support needed if I get the heavy duty bucket?
Thanks,
Steve
/ Chain hooks #15
Yes, even with the heavy duty bucket, you ought to add reinforcement. Many of us have seen heavy duty buckets bent in the middle.
And I agree with the other comment about not lifting a heavy load all on one side. I had a JD mechanic tell me that they have seen several guys with twisted loader frames from lifting way off center, usually with chain hooks, and there isn't really anything they can easily do to fix it. You just have to try to tweak it the opposite way a bit harder, and they don't like to be responsible for that.
Some dealers will not install non-factory add-ons like chain hooks, for liability reasons. One dealer told me that a dealer that would put chain hooks on ought to have his head examined, that he is asking for a lawsuit these days.
Whacky world! /forums/images/graemlins/wink.gif
So far, I've found pallet forks for my loader more useful than the bucket for lifting things, and I think I will add chain hooks to my pallet fork frame which is already some very heavy gauge tubing that shouldn't need reinforcing.
Shamrock 8ft. S/A Enlcosed K-9 Transport Trailer (A61574)
Shamrock 8ft. S/A...
2011 Terra Riser 300D-SA Fire Plow Tractor Attachment (A61572)
2011 Terra Riser...
(4) BASKET HAY TEDDER (A63291)
(4) BASKET HAY...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2016 Ford Fusion Titanium Sedan (A61574)
2016 Ford Fusion...
