Chain Hooks on Loader
/ Chain Hooks on Loader #1
gd165623
I hear about welding chain hooks on loaders and i want to add a reciever hitch and chain hooks to my loader but all i see at Tractor Supply are the regular chain hooks---are there different chain hooks made for welding on --or do you weld on the ones with the hole at the bottom or the clevis pin type? THANKS
/ Chain Hooks on Loader #2
Around here those weld on chain hooks are easier to find at a truck supply place, i.e. where truck up-fitters shop for hardware to install plows, sanders, etc.
Better source than TSC for hydraulics too - better PRICES !!!
/ Chain Hooks on Loader #4
AW Direct (above link) is where I bought the first batch.
Then on egadBay there were some weld on hooks (like 10) for 10 bucks or so.
/ Chain Hooks on Loader #5
My local Kubota dealer has the weld on type hooks. I forget what I paid for the last ones I bought but they were inexpensive. They are definitely the best type to get for welding on your FEL bucket .
/ Chain Hooks on Loader #6
Local Deere dealer here has weld on type hooks in stock for $8 each.
/ Chain Hooks on Loader #7
I didn't know weld on hooks existed. Thanks for the link - - - I just ordered some.
Reggie
/ Chain Hooks on Loader #8
If you have a chop saw.grinder,disk cutter, or even a hack saw, My dealer just cuts a grab hood to a fairly flat surface to weld them on. Ive done it a few times there isn't much material to remove.
/ Chain Hooks on Loader #9
Why all the rage to weld on hooks?
Is there a reason why nobody seems to just buy the bolt on type and drill a few holes and bolt them on? If people are worried about the bolts causing localized loads and failing the bucket locally, the same would happen with the weld-on (in my opinion) and if you load it up that much you probably have other problems on the way.
Am I missing something here?
It would seem that drilling 2 holes on the bucket per side, and bolting on the hooks would be easier, and more "reversible" if for some reason you wanted to take them off.
/ Chain Hooks on Loader #10
I used grab hooks with the pin for attaching a chain. Welded them on while leaving the holes for the pin. Then, got a short length of light wire chain and attached it by using the pin. Now, with benefit of a double snap catch, I can attach 5 gallon buckets on either side of the bucket and/or front via the center grab hook.
When fencing, I place T posts in the FEL bucket. Pull old wooden posts with the FEL and place them in FEL bucket, drive the T post with bottom of FEL with a pipe sheath covering so T post doesn't bend. Tools and supplies are distributed in the 5 gallon buckets. Trash such as busted electric insulators, pieces of wire, etc. goes into a 5 gallon bucket.
This lets me and a buddy work a fence line easily. He drives up to the fence and performs FEL operations at my direction while I perform whatever needs to be done.. pulling crooked/busted posts using chain in grab hook, driving new ones in, repairing/removing/installing electric insulators and t post clips.
Net, I PREFER the regular grab hooks and use the extra attachment points they provide to my benefit.
/ Chain Hooks on Loader #11
Your missing something!!!:eek:
I see you have a Kubota B3030..as I do. Try and explain how YOU are going to BOLT a chain hook to the upper lip of your FEL bucket? Then explain how you can ever WELD a hook to the upper lip. I looked at my own FEL bucket....clamped a 12" Cresant wrench onto the lip and could work it back and forth. A hook welded or bolted to that flimsy POS wouldnt last 2 weeks of hard work.
I took a piece of 2" x 3" angle...1/4" thick and welded it to the backside of that lip and down to join the other backside of the FEL bucket and THEN welded my hooks onto the 1/4" thick angle
/ Chain Hooks on Loader #12
Good Ideas!! Regular grabs are much cheaper too. Need to strengthen the bucket where theyre welded if you use them hard tho.
larry
/ Chain Hooks on Loader #13
I did the same thing, works well. I like the loop they have for hooking tie downs as well.
/ Chain Hooks on Loader #14
I don't have a Kubota bucket. I have an ATI bucket, and I bought the heavy duty one...
:D
I have not looked at it THAT closely, but it is very beefy, and I'll bet it would be OK. I also have bolt holes on the top side of the bucket for a bolt on grapple, so I could always bolt on a piece of angle there, and bolt the hooks to that...
Have to take a closer look.
/ Chain Hooks on Loader #15
I have the heavy duty round back Kubota FEL bucket.... it is extremely strong and reinforced on the top where the chain hooks are welded...no further reinforcement needed for that bucket. However, I have seen on other threads where lighter weight buckets DO need further reinforcement.... it's worth looking at carefully before welding.
/ Chain Hooks on Loader #16
:D
Well I bought the Kubota laoder because it fits the (limited) lift capabilitys of the tractor itself.
Dont matter what brand of bucket...but you need to LOOK and ASK before making statement to the affect that "people" need to just bolt on hooks. Everyone doesnt own the same equipment..and besuides that..bolt on hook will STILL give point loadings into the metal of the busket..which PROPERLY welded hooks wont ( ifi given a proper pad or mount surface)
/ Chain Hooks on Loader #17
Excuse me, but when did I EVER say "people need to just bolt on hooks"?
:confused:
I asked a question, because I don't understand why everyone seems to go to a lot of trouble to weld on the hooks. It was a question, NOT a statement...
I can certainly understand CASES where it makes sense to weld them on, such as if the bucket is not sturdy enough locally. My bucket does not seem to have that limitation, and also I think people need to keep in perspective how much (or little) load you can actually put on 2 hooks on the bucket with a sub 1k lift capacity. THAT is why I am asking. Sorry to get your panties in such a ruffle...
:confused:
EDIT: BTW, the welded on hooks that I have seen many people install, are just welded directly to the bucket, and not to an angle iron or other reinforcement pad, FWIW...
/ Chain Hooks on Loader #18
I would guess that people would opt to bolt them on for two reasons, one being that there are already avaliable holes to do it, or that they arnt set up to weld them on.Of cource where and how they are welded on depends on the stregnth of the area and the amount of the load.
Mine were welded on from the sealer, who also added a strip of metal across the top of all the buckets he sold, so I am lacking the 'pibut they would sure come in handy. I many times find i had to use my straps etc to secure and its hard to hook them to the hooks.
I would say its up to the individual and their needs.Ive read many posts here about not pulling ,etc. Ive done it all for 30 years and three ford tractors and havent done harm, so the question is is the tractor better built, or an I just not not overdoing it.
If I were the original poster, maybe search the other threads and find a method that most fits your needs.I have 3/8 hooks, and almost alwasy use 1/4 inch chains, and expect them to snap.
/ Chain Hooks on Loader #19
On the BX23 I bolted my 5/16" grab hooks...
The Hooks are forged and made in USA and I carry a 5/16" grade 70 chain...
I decided bolting was more than adequate for the capabilities of my BX...
/ Chain Hooks on Loader #20
everyone is saying what they did, but how bout some pictures....Please :D
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
2014 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2014 Chevrolet...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2021 Jeep Gladiator 4x4 Crew Cab Pickup Truck (A66736)
2021 Jeep...
2014 Ford Escape AWD SUV (A66738)
2014 Ford Escape...
2016 Mazda Mazda 6 Sedan (A66738)
2016 Mazda Mazda 6...
