chain holder
/ chain holder #1
frankie14001
akron,n.y
kubota L3130
here 2 picks of my chain holder i made. i welded a bottom on to a piece of rectangle tubing painted it orange and bolted to the side of the loader frame it works nice cause it right there when get off of the tractor i got the idea off tbn from other posts so thanks guys
/ chain holder
pic 2
/ chain holder #3
Nice idea! I've been trying to come up with some way to keep log chains with the tractor and your pics have got the wheels churning! Thanks.
/ chain holder #6
I'm glad the post helped you. It is rewarding to see that someone used it. Before I had the loader I put one box on each side, bolted to the clutch bellhousing FEL mount holes.
Now you need two more. Two long chains and one 8' chain is just right.
/ chain holder #8
frankie14001: ........Great post /forums/images/graemlins/cool.gif I'm sure many owners will say
why didn't I think of that /forums/images/graemlins/grin.gif
For all the smaller B series Kubota, I've included my
( portable/removable from it's subframe) version of a chain box.
Thanks for starting this post /forums/images/graemlins/laugh.gif ....RayBee
/ chain holder #9
Here is the top view , for reference. ....RayBee /forums/images/graemlins/smile.gif
/ chain holder #10
I borrowed the same design and mounting location from a prior TBN posting. Looks almost identical. Also painted it Kubota orange. Its beginning to look like Kubota OEM!
/ chain holder #11
Neat idea guys. I've lost 3 chains by bouncing them out of the FEL. Found 2 with the bush hog, never did find the third one ... probably buried it somewhere. Looks like I've got myself another rainy day project.
/ chain holder #12
You won't really appreciate the rectangulat tubing on the loader frame until you step of the tractor and the chain is literally at your finger tips. You can graps it without stopping.
The way you store the chain affects how easily it comes out. If you put the chain back by hooking one hook over the edge first, then putting the chain in and finally set the end hook on the edge, close to the seat. When you grab and pull the close hook gravity helps and the chain comes out fast. Almost like a real fast snake!
I carry three chains.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2018 Ford Transit 150 (A64911)
2018 Ford Transit...
3 Point Hitch Attachmnet (A66734)
3 Point Hitch...
John Deere 7200 (A64911)
John Deere 7200...
PORTA POTTY (A68842)
2018 RAM 3500 4X2 S/A DUALLY TRUCK (A69167)
2018 RAM 3500 4X2...
