Ceramic coating treatment
/ Ceramic coating treatment #11
I put a ceramic coating on one of my cars. It is good, however, all of the serious ceramic products want you to apply a "reload" product after every carwash, to beef up the ceramic (SiO2 or similar), improve the shine, and maintain the performance. In my opinion, if I have to apply a product and buff after every wash, I may as well have used a standard wax. Theoretically the ceramic is better, but a standard wax would also be pretty good if you reapplied it and buffed after every wash.
I applied the ceramic to a new car, so paint correction work was minimal. Applying the ceramic is tedious and requires care. The coating hardens to a glass-like material so you have to get the timing right. Apply the coating a panel at a time, let the carrier flash off, then buff. If you miss the window, it will harden and leave a mess. And you have to change applicators frequently, since the ceramic will harden on the applicator as you're working. I think I used about 6 applicators on a small car. Once the coating is done, I waited 12 hours and then applied a second product to increase the shine (the main ceramic coating was not that shiny).
One oddity I noticed is that the car gets dirty faster than our other cars, which others have noticed with ceramic too. I think it attracts dirt/dust more quickly.
I probably would not do it again, at least not with a pro product. I might try one of the consumer spray on products that is easier to apply and less involved/risky.
BTW, the ceramic is not permanent, it does ablate over time.
/ Ceramic coating treatment #12
Years ago I used a product called Ceram-Kote (I believe) on A severely blistered fiberglass hull of a boat it was a lot of prep work that I did myself and was a two part ceramic epoxy. unfortunately the boat ran aground during a storm on a sandy beach, it destroyed a lot of the gelcoat but the parts of the boat below the waterline that were covered in the ceramic epoxy were mostly undamaged so from personal experience I can confidently say ceramic coatings are very durable and worth the cost In my opinion especially if the prep work is done correctly.
Roflmao, I totally misunderstood this post, I was talking about, and my experience is with a completely different product i.e a barrier coat. I Definitely wouldn't apply this product to my car, a frequently used steel utility trailer, however, yes.
SANY SY35U EXCAVATOR (A59823)
SANY SY35U...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2009 Ford F-150 Ext. Cab Pickup Truck (A60352)
2009 Ford F-150...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
