Oil & Fuel Century 2535 or Branson 3510
/ Century 2535 or Branson 3510 #1
pat28743
Hot Springs NC
Century 2535
I have a Century 2535. The wiring to the ignition and fuel stop solenoid have burned up. Does any one have a wiring diagram that they could send to me? I've had no luck with Branson or any one else for
that matter. The short or whatever burnt out fuel pump also. While trying to find out what happened I broke the plastic cup of the fuel filter.. Is there any other existing tractor brand part
that will fit this?? Thanks in advance Pat28743
/ Century 2535 or Branson 3510 #2
We had a wiring harness burn up on an older 3510. There were 3 different wiring harnesses made and no way to easily differentiate between them. We ordered one and it was wrong. Then we ordered another and it was wrong. Then Branson said to order all 3 and take the one that works and return the others. I kid you not, it was frustrating. I think you will be hard pressed to get a reliable wiring diagram, we couldn't.
That plastic cup is common to a couple of brands at least. I think a TYM part fits, maybe a JD part, etc. But I do not have any part numbers handy.
Thank you Dave for your reply.It does look like Jawa and Kukje left Century owners high and dry. Its a darn shame.I really like this tractor.
Pat28743
/ Century 2535 or Branson 3510 #4
Pat28743
You might be right, but this issue of not being able to identify the correct wiring harness is no better if you have a Branson vs a Century. I'll agree they are good machines, but as a Branson dealer I am sometimes frustrated by the "parts department".
Thanks Dave. I guess I'll just have to pick it back from the fuse panel. As for the stop solenoid I'll put in a cable instead, There is a TYM dealer fairly close, I'll check for the fuel filter cup.
pat28743
/ Century 2535 or Branson 3510 #6
