Ccw pto clutch
/ Ccw pto clutch #1
Goatfeathers
Does anyone know where I can get a override clutch for a counterclockwise rotating pto?
/ Ccw pto clutch #3
Open it up and see if you can turn the fingers around...
/ Ccw pto clutch #6
Like aczlan said, if you put the clutch on the implement side, it will be operating correctly in a counter-clockwise direction. If it is ratcheting on the implement side, then you either have a clockwise rotating PTO, or a reverse-rotation clutch already. Put it on the tractor and you should be good to go. :thumbsup:
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
Toro Reelmaster 4000 D Mower (A65579)
Toro Reelmaster...
