Ccw pto clutch
/ Ccw pto clutch #1
Goatfeathers
Does anyone know where I can get a override clutch for a counterclockwise rotating pto?
/ Ccw pto clutch #3
Open it up and see if you can turn the fingers around...
/ Ccw pto clutch #6
Like aczlan said, if you put the clutch on the implement side, it will be operating correctly in a counter-clockwise direction. If it is ratcheting on the implement side, then you either have a clockwise rotating PTO, or a reverse-rotation clutch already. Put it on the tractor and you should be good to go. :thumbsup:
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
Cat CB24B (A60462)
Cat CB24B (A60462)
Cat CB24B (A60462)
Cat CB24B (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 50 (A60462)
