Toplink CCM Hydraulic Toplinks have Arrived!!
   / CCM Hydraulic Toplinks have Arrived!! #1
HayDR
Veteran Member, Approved Advertiser
Johnson City, TN
JD 2040,2240, 2355, 2755, 4055
The CCM hydraulic toplinks and side links with double piloted check valves will arrive at CCM on Monday April 2. Please give us a day to check them in before you call and place your order. We will start taking orders Tuesday April 3. ALL sizes should be available.
Thank you for your patience and support.
Mark Carter
   / CCM Hydraulic Toplinks have Arrived!! #2
Fantastic. I hope your shipment contains plenty of each size.
   / CCM Hydraulic Toplinks have Arrived!! #3
Toplink for the TC40DA NH series should be their middle size cylinder, 18-26"??
   / CCM Hydraulic Toplinks have Arrived!! #4
What does your existing top link measure? You need to get one that is close to that measurement.
   / CCM Hydraulic Toplinks have Arrived!! #5
My L5030 is Cat 1/2 and i have an implement where I'm opening the top-link to 34" now. I think it's really because the side arms are longer. Is there a way to extend the hydraulic links? maybe an extension on the cylindar? I don't need it to throw more, just reach farther ;)
-Brian
   / CCM Hydraulic Toplinks have Arrived!! #6
Unfortunately, my tractor won't get delivered for 2 weeks, so I can't really measure it right now. Thanks for the suggestion, though. I was hoping someone with a TC40DA might shed some light on this.
   / CCM Hydraulic Toplinks have Arrived!! #7
I can check mine for you if you tell me what to measure.
   / CCM Hydraulic Toplinks have Arrived!! #8
Thanks, slippy. I don't know for sure. I guess it's the length of the TL from end to end all the way extended and all the way shortened??
   / CCM Hydraulic Toplinks have Arrived!! #9
I tried to measure center of pin at bottom to center of pin at top. Cranked all the way in is about 15" and all the way out is about 20", so about 5" of travel. Hope this helps.
   / CCM Hydraulic Toplinks have Arrived!! #10
That extremely helpful. I believe that's all I need. They suggested their medium might work, but that's 18-26" according to the guy on the phone from CCM.
Utility Trailer (A52377)
Utility Trailer...
2020 Autocar ACX Xpeditor Garbage Truck (A55852)
2020 Autocar ACX...
2024 John Deere 6110M MFWD Tractor (A53485)
2024 John Deere...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
