CC 2042 problem?
/ CC 2042 problem? #1
JohnNH
New Hampshire, USA
Cub Cadet 2042 & Yanmar324 Tlb
I have an 05 CC2042 and it has performed perfectly all season. This past Saturday, I was in the process of moving equipment around in my shed in preparation for winter up here in New Hampshire. I started the tractor and when I went to back up, it was very sluggish and after about 15 feet of backing up, it stopped. I shut it down and checked all the fluids (engine, tranny, rear) and everything is full. The engine didn't rev up = so it didn't sound like the tranny was slipping. I was concerned that something serious could be happening, so I pulled the lever on the rear and have now storred it for the winter.
Note: It was about 20 degrees = should I have warmed it up for a while?
Any ideas?
Thanks,
JohnNH
/ CC 2042 problem? #2
Any chance you left the parking brake on? I've done that a few times and the symptoms sound like what you've described. Were you intending on storing it for the winter? If it's working properly, it could be a big help with all your snow /forums/images/graemlins/smile.gif
/ CC 2042 problem?
Rob,
Brake was off. I am storing the tractor in my shed = out of the way. I have a 10HP snow blower that I use. I have someone plow my driveway = over 200' long, 2 cars wide and a 50 by 75 turn around. The snow blower does the paths to the house, shed, etc.
When I am ready to retire the snow blower, I will buy a blower for the tractor (large price).
Thanks,
John
/ CC 2042 problem? #4
Bad gas or water in it - I would have looked at it more before storing it for winter - why eat up your warranty in storage (not saying this requires it but you never know)
I would pull the gas filter to see if gas flows good
throw some gas treatment as well as Stabil in it once you get it going again.
/ CC 2042 problem? #5
Very good advice. Especially concerning the warranty. Repairs can be extremely expensive. Amount of use doesn't seem to matter, but the amount of time you own the machine does.
/ CC 2042 problem?
ducatti996 and all,
You hit it right. I took your advice and pulled the tractor out of the shed, checked the filter and had a combination of water and what looked like a grain like residue ( This made me check the gas can that I used last and this was the culprit = must have left the lid off and invited foreign substance into can). I cleaned the fuel line, drained and cleaned the tank (that was fun), replaced the filter, and it ran great. I had already put some stabilizer in and put new stabil in the fresh load of gas. Note, the fluids are all full and circulated, I re-greased and lubricated every possible moving part and it's back in storage again (It's close to the shed door and easy to pull out during the winter if needed).
As always, thanks for all the help.
John/NH
/ CC 2042 problem? #7
Its always good to hear!!
Cubs been taking a beating lately and as it turns out more than a few beatings were mis-directed towards Cub /forums/images/graemlins/grin.gif
/ CC 2042 problem? #8
Good to hear you are back in action. Maybe it's a good thing the gas filler opening is almost big enough to reach your arm in /forums/images/graemlins/tongue.gif!
G/luck
Joel
/ CC 2042 problem?
Joel,
I used a little yankee creativity. I used a 12 volt bildge pump attached to a flexible hose (boat stuff that I had laying around). it did a great job of getting the fuel out and even provided enough suction to clean out the tank I reduced the size with a short section of plastic tube and used that to clean out the gas line.
Note: Without the help of the people on this outstanding board, I would likely have called the dealer and donated some Christmas money.
Thanks again,
John
/ CC 2042 problem? #10
</font><font color="blue" class="small">( Joel,
I used a little yankee creativity. I used a 12 volt bildge pump attached to a flexible hose (boat stuff that I had laying around). it did a great job of getting the fuel out and even provided enough suction to clean out the tank I reduced the size with a short section of plastic tube and used that to clean out the gas line. )</font>
12V bilge pump?? Good idea, but that makes be a little nervous. Bilge pumps (I don't think) are rated to pump flammable liquids. 12V DC motors use brushes, and brushes make sparks. Spark + Gasoline = BOOM!
I'd consider yourself lucky you didn't go up in flames with your nice Cub.
Am I off base here?
Chris
/ CC 2042 problem? #11
exacltly what I was thinking. I think if I had to do that, I'd use by Tempo Oil boy extractor (uses vacuum) to suck the gas out. Takes the oil out great of the pwc, tractor, lawn mowers, etc.
/ CC 2042 problem?
I tried the pump in an out of the way area first (gas can to gas can = about a pint of fuel) and nothing happended.
For what it's worth, I did have a fire extinguisher close by.
You both have a strong point and if it was luck on my part, I should go buy a lottery ticket.
If this ever happens again, I will use a hand operated manual pump = no sparks left in my old body.
Now I am feeling a bit nervous (after the fact) and I am not going to tell my bride about this one.
Thanks for the input,
John
/ CC 2042 problem? #13
</font><font color="blue" class="small">( ..If this ever happens again, I will use a hand operated manual pump = no sparks left in my old body.)</font>
Bahhh! Where's the fun in that John! /forums/images/graemlins/grin.gif (kidding) There's lots of close-coupled electric pumps out their to handle flamible liquids. Just gotta make sure it's rated for the application. Heck- just s/d your 2042 at idle to get the kohler kaaa-POOWWW!!
G/luck
Joel
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
