Cav fuel pump leaking.
/ Cav fuel pump leaking. #1
Welsyng
Ih 474
Hallo.
My cav fuel pump is leaking from the big screw down at the bottom of the pump.
Is this something I can fix myself, or does the pump need to be sent to a mechanic?
I am unsure if theres some sort of rings I can change so it doesn't leak anymore, and I don't know if there are some springs or something I can break if I take the screw out
Sorry for my bad English 😁
/ Cav fuel pump leaking. #2
Welcome to TBN
Most inj pump repairs requires very knowledgeable technician or IP repair shop.
/ Cav fuel pump leaking. #3
Yes there is an oring that can be changed.. & yes, there are springs AND SHIMS in the cap..
U should get a KIT w/ the correct size oring.. 7135-110.. CAV/Delphi
Ty for the answers.
Will the spring pop out if I remove the screw? In other words is it easy to change the oring my self?
I am not a mechanic, but I have changed some springs in the filter system of the pump my self before, so I am not totally incapable.
Do you know what the small screw is for? And do I have to unscrew that one before I unscrew the big?
/ Cav fuel pump leaking. #5
Sorry but I don't know answer to your question.
Jim
Problem solved.
I took the screw out and changed the oring. The springs inside didn't pop out :)
I already had a reseal kit from previous repairs I made and there was an oring I could use
/ Cav fuel pump leaking. #7
Glad u fixed it.. keep the kit close by..
on those pumps, if u stop 1 leak another starts.. unless u do them all at once..
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59912)
2007 TRAILMOBILE...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2019 JCB 457 (A60462)
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
